RV.Net Open Roads Forum: I need help removing my broken water heater drain plug
 > I need help removing my broken water heater drain plug
albow
Harpersville, AL, USA
Posted: 10/10/21 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
I was removing it to winterize today and about 1/4 turn out, it broke off. I guess I tightened too tight before. I've had the same thing happen on my boat pontoon so I learned to take a drill bit and wallow out an indentation in a spot, being careful not to scarf the threads, so that my file can fit in the hole just right and have something to grab, as this never happens to leave any part of the plug where you can grab it with pliers or anything. Well, apparently, my boat plugs are not nylon because this technique wouldn't work with my nylon heater plug. I essentially could not get a groove going for an ideal catch point. I can't believe I couldn't get this to happen. Fortunately, this hole is slightly smaller than my pontoon, so my file grabbed the soft nylon when I shoved it in far enough. Boy, did it grab! I shoved inward forcefully so it wouldn't spin, but I couldn't get it to budge. Then, I but some locking pliers on the file to get leverage to rotate it. It held so strongly that I broke my file (it was a half round mf for those of y'all who remember the joke). It still didn't budge. So, I'm at a loss as to how to remove the rest of it. My best guess at this point is to stick a lighter in the hole and try to melt it away but I'm not crazy about the possibility of getting some melted plastic in the tank. Would the chances of that be minimal, since the drain is angled towards the ground a little instead of parallel? I tested burning the part of the plug that did come out with the head and it turns black and slowly melts. Any better or easier ideas? BTW, the head is 22mm which correlates to around 7/8" but I'm just seeing 1/2" plugs. Is that actually the same plug and the inner diameter is actually 1/2"? Thanks.
Alan & Tommie. 2003 Dodge 3500 SRW SLT Quad Cab, Cummins 5.9 HO, 6 speed manual and 3.73's. 2007 Pilgrim Legends Mid Profile 33RKS-M5 5th wheel, Prodigy, Superglide 14K hitch (already very glad I got it).
trailrider
Idaho Is Full! Don't Move Here!!!
Posted: 10/10/21 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Go to the hardware store and buy a "sprinkler riser removal tool." I have removed several with one of these, works perfect.
https://www.homedepot.com/p/1-2-in-and-3........Plastic-Nipple-Extractor-26076/100203404
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
DancinCampers
Louisiana
Posted: 10/10/21 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
I had one break off on my previous coach. I used a pocket knife to lift up an edge, then needle nose pliers to twist it out.
Dan & Sharon (Kasey, Our Yorkie, RIP 9Jan'05-26Jul'17)
2012 Winnebago Journey 36M
2006 Jeep Liberty, Blue Ox Aventa II, SMI Silent Partner
If You Obey All The Rules, You Miss All The Fun
mike-uswest
Central Point, OR, USA
Posted: 10/10/21 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Get an easy out, drill the right size hole to fit and just turn it out.
Mike
2003 Dodge 2500 CTD, 4X4,
Arctic Fox 25Y
poppa
Dallas, TX
Posted: 10/10/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
drill it close to the id it is and pry out what is left of the plug.
ferndaleflyer
everywhere
Posted: 10/10/21 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Its plastic, don't make it harder than it needs to be and an easy out will only make it tighter.
time2roll
Posted: 10/10/21 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Go down to Lowes or HD and pick up an internal pipe wrench.
675w Solar pictures back up
#1Flyboy
California
Posted: 10/10/21 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
If the remaining threads are of plastic or nylon, you could heat up a screwdriver head & melt a grove/ slot in the material. Then cool down the screwdriver head & unscrew the remainder…A picture of your problem would be helpful….
Boon Docker
Posted: 10/10/21 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
X2
larry cad
ohio
Posted: 10/11/21 03:29am Link  |  Quote  |  Print  |  Notify Moderator
When you get it out, don't make the same mistake by replacing it with another nylon plug. I started using a brass plug 15 years ago and it is still working fine, including easy out with a crescent wrench.
Our Travel Blog
