RV.Net Open Roads Forum: I need help removing my broken water heater drain plug
 > I need help removing my broken water heater drain plug
albow
Harpersville, AL, USA
Posted: 10/11/21 04:56am Link  |  Quote  |  Print  |  Notify Moderator
trailrider wrote:
Go to the hardware store and buy a "sprinkler riser removal tool." I have removed several with one of these, works perfect.
https://www.homedepot.com/p/1-2-in-and-3........Plastic-Nipple-Extractor-26076/100203404
Thanks. I'll give it a shot.
Alan & Tommie. 2003 Dodge 3500 SRW SLT Quad Cab, Cummins 5.9 HO, 6 speed manual and 3.73's. 2007 Pilgrim Legends Mid Profile 33RKS-M5 5th wheel, Prodigy, Superglide 14K hitch (already very glad I got it).
albow
Posted: 10/11/21 04:58am Link  |  Quote  |  Print  |  Notify Moderator
DancinCampers wrote:
I had one break off on my previous coach. I used a pocket knife to lift up an edge, then needle nose pliers to twist it out.
Not enough to grab even if I made a piece loose like you suggest. Thanks
albow
Posted: 10/11/21 05:00am Link  |  Quote  |  Print  |  Notify Moderator
#1Flyboy wrote:
If the remaining threads are of plastic or nylon, you could heat up a screwdriver head & melt a grove/ slot in the material. Then cool down the screwdriver head & unscrew the remainder…A picture of your problem would be helpful….
Essentially what I did with the drill. I had plenty of traction. Enough to break my file.
albow
Posted: 10/11/21 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everybody. I'm going to give the first suggestion a shot.
phillyg
SWFL
Posted: 10/11/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
Excellent suggestion! If that doesn't work, melting it out might work, and I wouldn't worry about any getting inside.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Dusty R
Charlotte Michigan 48813
Posted: 10/11/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
I replaced the plug with a st. ell, then a ball valve. Makes if easy to drain the tank.
I looked and see I didn't use a st. ell, there was room for the ball valve plus a brass garden hose adapter straight from the tank.
* This post was edited 10/11/21 05:37pm by Dusty R *
John Wayne
Long Beach, Ca
Posted: 10/11/21 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
As I recall talking with Attwood you want to ONLY use the nylon plug. It is also used as a safety device designed to blow out if pressure gets too high. I know that's what the pressure relief valve is for. Just say that's what I heard for an Atwood rep.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
SteveB
Rhode Island
Posted: 10/11/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
I carry a set of easy-outs in my tool box just for this purpose. Picked up at Harbor Freight a few years ago when my heater plug split. needed again today when the replacement plug split. The Camco plugs last a couple of years then its easy-out time again. [emoticon]
2015 RAM 3500 CTD Auto 4X4 CC Dually, Reese 20K
SOLD 8/2015 '01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
Sjm9911
New Jersey
Posted: 10/12/21 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Not sure if you could get a hacksaw blade or simmiler inside there, but on old metal drain pipes you used to cut it from the inside out to the threads, in like 4 spots then it just falls out. You need to use like a keyhole saw one. Not a full hacksaw.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
albow
Posted: 10/14/21 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Well, that didn't work. It sure gripped but I couldn't turn it. I'm going to get my stronger neighbor to give it a go and then try something else. I wonder if it's because it's nylon and the sprinkler heads are maybe pvc?
