RV.Net Open Roads Forum: I need help removing my broken water heater drain plug
 > I need help removing my broken water heater drain plug
albow
Harpersville, AL, USA
Posted: 10/14/21 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Stonger neighbor didn't work. Trying other options tomorrow.
Alan & Tommie. 2003 Dodge 3500 SRW SLT Quad Cab, Cummins 5.9 HO, 6 speed manual and 3.73's. 2007 Pilgrim Legends Mid Profile 33RKS-M5 5th wheel, Prodigy, Superglide 14K hitch (already very glad I got it).
Boon Docker
Posted: 10/14/21 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
albow wrote:
trailrider wrote:
Go to the hardware store and buy a "sprinkler riser removal tool." I have removed several with one of these, works perfect.
https://www.homedepot.com/p/1-2-in-and-3........Plastic-Nipple-Extractor-26076/100203404
Well, that didn't work. It sure gripped but I couldn't turn it. I'm going to get my stronger neighbor to give it a go and then try something else. I wonder if it's because it's nylon and the sprinkler heads are maybe pvc?
With a tool like that you are expanding the plug making it even tighter.
Heat up a screwdriver and melt a couple groves (top and bottom) in the plug right down to the metal water heater threads.
Then take the screwdriver (once cooled), place it between the plug and the water heater thread and pry the plug out.
trailrider
Idaho Is Full! Don't Move Here!!!
Posted: 10/14/21 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
It has never failed me on any I've removed.
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
albow
Posted: 11/13/21 01:01am Link  |  Quote  |  Print  |  Notify Moderator
Sorry I didn't post a conclusion to this. By now, I have forgotten exactly how I removed it but it seems like I grabbed what I could with pliers or vice grips and plied, pull, tore it out I think. Unfortunately, threads were boogered just enough that I couldn't get even a metal plug to run in and clean the threads, primarily because the very edge got boogered as well, thus preventing anything from starting. I believe I then minimally got a tap started, ran it in slightly, then replaced it with the metal plug, which I kept advancing as far as I could comfortably and following it again over and over with the metal plug, then finally inserting the plastic plug. Either the threads are longer on the new plugs or I don't have it fully inserted, but it feels as tight as I want to chance. I will know once I hook up next spring, at which time I believe some teflon tape will finish the job if it is leaking. I certainly hope so lol. Thanks everyone.
