RV.Net Open Roads Forum: Tech Issues: "All-terrain" step stool??
 > "All-terrain" step stool??
profdant139
Posted: 10/10/21 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
There are times when I need a step stool that can adapt to uneven surfaces -- we mostly boondock, and an ordinary step stool can't cope with rocky and un-level ground. Probably would have adjustable legs, I guess.
Do you know of a product that fills this need? Thanks in advance for your collective wisdom.
(And if someone takes this idea and makes millions off of it, I will be your first customer!)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
profdant139
Posted: 10/10/21 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
I think I just found a possible solution -- it is kind of low to the ground for what I had in mind, but it's a start:
Possible solution
2112
Posted: 10/11/21 03:13am Link  |  Quote  |  Print  |  Notify Moderator
We have been using the fixed step version for years. The only negative experience we have is if the feet sink into the mud the black rubber foot pads detach when you pull it out. It can be difficult pulling the pads out of the mud with pliers. If I'm going to place it in the mud I leave the legs folded up.
Other than that it's a great step
2013 KZ Durango 2857
Dick_B
Palos Heights, IL USA
Posted: 10/11/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Amazon has one by Camco with adjustable legs from 7.5 to 9 inches.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
phillyg
SWFL
Posted: 10/11/21 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Allow me to be a wisenhimer(sp) and opine that wood blocks can be helpful.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
CA Traveler
The Western States
Posted: 10/11/21 08:36am Link  |  Quote  |  Print  |  Notify Moderator
I have a similar one to the posted link and it works great.
2014 Grand Cherokee Overland
Bob
gbopp
The Keystone State
Posted: 10/11/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
You were close. [emoticon]
wis·en·heim·er
/'wiz?n?him?r/
Learn to pronounce
nounINFORMAL•US
a person who behaves in an irritatingly smug or arrogant fashion, typically by making clever remarks and displaying their knowledge
NamMedevac 70
Reno
Posted: 10/11/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
You could try the orange plastic leveling blocks that most RVers have for leveling the trailer and/or raising the tongue jack higher off the ground. Their sharp edges bite into the ground fairly well. They are of course stackable in varying heights as desired and sold at all RV stores and Walmart, etc. Two stacks side by side may do the job and you may already have some. They use to be cheap to buy but now with roaring inflation
Timmo!
South-central Oregon...on the river
Posted: 10/12/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
We used a shallow wooden box turned upside down until someone decided they needed it more than I.
So I now use two of these from Harbor Freight. Zip tied two together and it works (about the same size of the steps). Not the best but better than others so far. It does not sink into mud as much, about the right height and will fold up (priced at $7 each). Wood blocks are no bueno, they flip over easy and attract mud. Steps with round legs submerge into soft sand and mud.
https://www.harborfreight.com/one-step-f........-black-57576.html?_br_psugg_q=step+stool
Timmo!
...oops double post
