RV.Net Open Roads Forum: Travel Trailers: Suburban SW6DE questions
 > Suburban SW6DE questions
Hornnumb2
Baytown, TX
Posted: 10/11/21 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Does the switch inside the trailer work both gas and electric depending on where the electric switch is on outside? Thanks
Boon Docker
Posted: 10/11/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
If you have just one WH switch inside the trailer that is for propane operation only. The switch for electric operation is a manually operated switch attached to the front of water heater.
canoe on top
Denver, CO, US
Posted: 10/12/21 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Suburban heaters unually have a switch on the unit that can be turned off so that if you accidently turn on the switch inside when the unit is empty it won't burn out the electric element. In everyone that I have seem, there is, also, an electric switch inside. As mentioned, there's a separate switch for the propane heater.
Posted: 10/12/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Appears it could be either. Mine is electric only switched at the water heater and propane only switched in the trailer.
Should be an easy test to figure out what runs what from where though. All it requires is knowing what hot water feels like vs cold.
2017 Heartland Torque T29
Boon Docker
Posted: 10/12/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
So as to not confuse things here, do you have one switch or two inside the trailer for the water heater?
wnjj
Cornelius, Oregon
Posted: 10/12/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
No, the outside switch only turns on or off the electric element and has no effect on gas.
In addition to the gas on/off switch inside, some RV's have another inside switch for electric which is connected in series with the outside one (both need to be on). Others, like mine, hardwire the electric so the outside switch is the only way to turn on/off electric.
You can also run gas and electric simultaneously for faster warm up. In this case an either/or switch wouldn't make sense.
