RV.Net Open Roads Forum: Anyone else run out of diesel ?
 > Anyone else run out of diesel ?
LandYacht35diesel
Florida STAYcation
Posted: 10/11/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
.... what a horrorShow ! .... got all sorts of suggestions.... finally got THE RIGHT INFO from a long haul trucker on another PERFORMANCE CAR FORUM who has 3.4 million miles under his belt
Bruce Brown
Northern NY
Posted: 10/11/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Just need to reprime the system. On our MH it's a series of turning on the key without attempting to actually start it. On one of my farm tractors there is an actual manual priming pump on the filter housing.
As always, check your manual, there is always a way.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
oldave
Tx
Posted: 10/11/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
You want someone to ask what he told ya?
Ok, what was the right info?
LandYacht35diesel
Florida STAYcation
Posted: 10/11/21 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
BB ... but it was TOTALLY RUN OUT ! MH was stored with 1/2 tank of fuel and all that was stolen ! This is a Cummins 5.9 12 valve with a manual lift pump ....
I still don’t have it entirely fixed ... I’m running it off a 5 gallon gas can !
Oh what a LEARNING EXPERIENCE!
jdc1
Rescue, Ca
Posted: 10/11/21 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Tank, fuel and pump were stolen? Or just the fuel?
LandYacht35diesel
Florida STAYcation
Posted: 10/11/21 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
oleD ..... he said ... I hope you didn’t run it COMPLETELY OUT of fuel !
Well I did ... the prob as I understand it ... UNLESS you have a max suction pump to pull the new fuel out of a partially filled main tank ... you’ll PLAY HELL getting the fuel up the draw tube UNLESS you have a almost totally filled tank
LandYacht35diesel
Florida STAYcation
Posted: 10/11/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Just the fuel as far as I know know.... but the thief could have sabotaged the inside of the tank with debris.... don’t know yet
pianotuna
Regina, SK, Canada
Posted: 10/11/21 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
How awful.
I had a dual tank on my 1987 diesel class C. The switch to change to the other tank would not always work. I had to press on a dill and schraeder valve while some one else turned the key to pump fuel into the lines.
Regards, Don
oldave
Tx
Posted: 10/11/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, that's a low-down thing to do. More than likely all they wanted was the fuel.
Since you have it running off the 5 gal can, can you go fill the tank?
I have primed before by using air pressure ( low ) at the tank fill opening.
I placed a shop rag as somewhat of a seal and applied low but constant pressure
while someone has a fuel line cracked open at the engine until fuel appears.
Good luck
Ava
Vancouver Island. BC Canada
Posted: 10/11/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming there is enough clean fuel in the tank, that manual push lever on the pump is there to bleed the system. Open the banjo fitting on top of the inline fuel filter, and you may have to crack open a couple injectors then pump away till the fuel spits out. Good luck.
