RV.Net Open Roads Forum: Travel Trailers: What causes soft floors
 > What causes soft floors
Wyldfire
ID
Posted: 10/19/21 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
jdc1 wrote:
Yep. Dryrot. Usually found under sinks, in front of shower/toilets, and sometimes a window or vent left open. Very seldom does it happen from below.
I would disagree. On some brands of newer trailers using foam sandwich floors that are only protected with darco. Rocks get thrown up and pierce this lightweight material. Driving in rain causes water to be thrown in the holes leading to break down of the wafer thin wood bonded to the foam. Mold moves in causing further damage.
tinner12002
Lafayette Ind
Posted: 01/03/22 05:28am Link  |  Quote  |  Print  |  Notify Moderator
The soft spot we have is due to the heating duct and the way Keystone cuts/installs it into the floor. Its right where we step down off the steps from the bedroom/bathroom and into the living area. I've read where others have had the same issue, same spot.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
Lantley
Ellicott City, Maryland
Posted: 01/03/22 09:11am Link  |  Quote  |  Print  |  Notify Moderator
What causes soft spots in floors? What can be done to prevent that? How serious is it?
Soft spots maybe the result of moisture from a leak. They may also be the reult of poor construction techniques and inferior sub floor material.
They can easily be avoided however the manufactures have to committ to designing and building a better unit vs. building units with known construction flaws and selling them anyway.
On the other hand consumers cannot me so price focused that they refuse to buy the prperly built unit, because they don't wnt to pay a few grand more to get a unit that was built right from the start.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Huntindog
Phoenix AZ
Posted: 01/03/22 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
All true but, I do not see that happening in my lifetime.
So my approach is buy a unit that has the things I cannot fix or upgrade, modify etc. such as a stout frame, and then mod it to suit me.
As it happens, these things also make it easier to sell for top dollar when the time comes. I have sold 3 TTs so far. In each case, the first one to look at it bought it, and for more than I was expecting to get.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1380watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
Lantley
Posted: 01/03/22 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
I hear you Hunting Dog and I sort of agree with your upgrade what you can philosophy. Except sandwhich floors are sort of structurally compromised from the start. The foam will not remain ridged for the lifetime of the RV. It is inevitable that soft spots will develop in high traffic areas.
In some cases there is not a lot you can do in certain scenarios to repair this issue.
Sandwich floors are very common but they are really something to avoid.
In order to avoid the sandwhich floors you have to migrate to a more expensive unit. To complicate it even more, sandwhich floor are inherently structurally compromised. The floors become even more a liabilty when they are not supported properly or compromised by a duct are wiring chase.
Many are not aware that the sandwich floors are a liabilty, they don't understand why its important to have t&g sub flooring on their must have list.
To their credit sandwich floors are lightweight and provide insulation, but if the floors are not sturdy they quickly become a liabilty.
Beefing up the sandwich floors can be a simple task or it can be very involved.
Avoiding the floors from the start is the best solution. Convincing manufactures not to use sandwich floors is a better solution. But Huntingdog is probably right. SAndwhich floor are heere to stay for the foreseeable future
Gdetrailer
PA
Posted: 01/03/22 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Can you point out the specific models of RVs that use T&G subfloors and conventional home floor structure?
I have never seen such setup in any RV I have been in so I highly doubt what you say is true..
Been in RVs from the 1960's and up and so far none of those were constructed like a conventional home floor with T&G.
The problems you state with sandwich floors is not 100% true in all cases. The problem stems from manufacturers reducing the thickness of the sub floor. I have a 1980's TT which has 1/2" thick plywood as a subfloor, but it is also glued (laminated) to the Styrofoam insulation below it and under the Stryofoam is as 1/4" plywood layer.
Modern RVs instead of using 1/2" plywood subfloor are using 1/4" or a bit thinner MDF or strand board to save weight and expense and that IS the real problem.
The only way you can avoid the thinnest subfloors is to make sure you are not choosing the "Lite" versions but then it now is heavier than what everyone wants to tow with can tow and not to mention far more expensive..
MDF and strandboard can no longer be avoided, the cost of real plywood will drive a lot of consumers away from the RVs..
* This post was edited 01/04/22 08:05am by an administrator/moderator *
Lantley
Posted: 01/04/22 05:14am Link  |  Quote  |  Print  |  Notify Moderator
Does it matter which part of the sandwich is faulty. If it's the thickness of the plywood portion or the density of the foam either way the product loses its rigidity and creates soft spots.
Why the sandwich fails is less important than the simple fact RV manufactures are continuing to use questionable products and questionable construction methods. The consumer ends up holding the bag of soft floors!
I agree sandwich construction is generally found in "Lite" units.But I don't believe it's exclusive to light units.
The real bottom line is units that don't use sandwich construction are generally more costly which makes those units less desirable to $$$ focused consumers.
wowens79
Georgia
Posted: 01/04/22 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I've got one with the sandwich floors and it is awful. I've got soft spots in all the high traffic areas. I had no clue about this when we bought the camper. I would avoid it at all costs.
I'm wanting to go to a 5th wheel, but really dread trying to sell this one. I've looked at repairing, but it looks like it will be a huge undertaking.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
Gdetrailer
PA
Posted: 01/04/22 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Your avoiding my question [emoticon]
Please point out the exact models and manufacturer brands which does not use a "sandwich" floor construction.
If you can't point out any models, then say so and then stop referring to that method as sandwich..
Sandwich is not the proper term for the construction of composite floor, wall or roof.
Gdetrailer
PA
Posted: 01/04/22 08:40am Link  |  Quote  |  Print  |  Notify Moderator
For the record.. The SUBFLOOR thickness and type of material IS the problem, not the construction method.
Yes, some manufacturers skimp on the subfloor thickness and type of material on some models and that IS the problem.
