RV.Net Open Roads Forum: Need advice on 50 ft cable to portable solar panel
 > Need advice on 50 ft cable to portable solar panel
Posted: 10/12/21 05:40am Link  |  Quote  |  Print  |  Notify Moderator
How about making a 20ft 10AWG extension cable. Place your panel where you want it. Add the extension if the existing 30ft doesn't reach the camper.
Do you have a PWM or MPPT controller?
2013 KZ Durango 2857
Tom_M
New Hope, MN
Posted: 10/12/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
ktmrfs wrote:
buy a 12Ga 3 wire extension cord, cut the ends off it and solder the green wire to either the black or white on one end do the same at the other end soldering to the same color you did at the first end.
Another approach is to make adapter plugs to go on each end and jumper the wires at the adapter. This way you have a dual purpose cable. Remove the adapters and use it as a regular 120 VAC extension cord.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 1978 VW Bug convertible
Minneapolis, MN
time2roll
Posted: 10/12/21 10:07am Link  |  Quote  |  Print  |  Notify Moderator
profdant139 wrote:
Very interesting points about moving the controller -- I will have to experiment with that to see how much difference it makes.
Panel is probably 18 to 22 volts and is cut to 14.x at the controller.
If the 18 volts drops to 15 through the wire to the controller it may not matter much as the controller will still put 14.x on the battery.
If the controller is at the panel you have 14.x going through the long wire and limiting power to the battery.
675w Solar pictures back up
ktmrfs
Portland, Oregon
Posted: 10/12/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
for a PWM controller at the battery, as long as voltage drop doesn't get down to below around 15V drop will have almost no effect on charging current. For a MPPT controller output may drop some due to the power loss in the cable that the MPPT controller normally could use. Worst case MPPT controller will end up delivering the same power as a PWM controller when the voltage drop gets big enough.
2011 Keystone Outback 295RE
jaycocreek
Idaho
Posted: 10/12/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think you will notice any difference,the way there aimed is far more important for incoming amps/watts...
Two 100 watt portable panels laying flat on my truck camper roof..
Minutes later,standing on the roof aimed at the sun..
* This post was edited 10/12/21 01:20pm by jaycocreek *
profdant139
Posted: 10/12/21 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I am going to display my ignorance here, so be ready to laugh. How do I tell what kind of controller I have?? It is built in to the portable panel -- but I bet I could un-attach it, with enough brute force. [emoticon]
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
jaycocreek
Idaho
Posted: 10/12/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
What portable solar panel do you have?
Bobbo
Wherever I park
Posted: 10/12/21 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I'd be willing to bet it is PWM since it came on the panel. My recommendation, get a good MPPT (I chose Victron SmartSolar) and put it at the batteries. Then disconnect your panels from the OEM controller and run them directly to the MPPT controller.
One caveat. I have not been able to find a good weatherproof MPPT controller. You will need to protect it if it is going to be exposed to the elements.
Bobbo and Lin
