RV.Net Open Roads Forum: Truck Campers: Looking for options
 > Looking for options
StirCrazy
Kamloops, BC, Canada
Posted: 10/12/21 06:34am Link  |  Quote  |  Print  |  Notify Moderator
So we did our first real trip in the camper (usaly use the 5th wheel and the camper has been for my solo travels) but the wife loved it. not enough to get rid of the 5th wheel but enough to look at a newer caper with a north south bed and bigger bathroom and so on. I max my truck out at about 4000lb and I was looking at the artic fox 865. everyone has told me that they are one of the bestbuilt on the market but thats just from what the people I know are saying. I would like to get as much bang for my buck for a 4000lb or less wet weight camper. I do have a long box if that makes a huge difference. anything else I should be looking at? we do camp in colder weather, not crazy cold but I dont want the wether to stop me from traveling.
thanks
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Bedlam
PNW
Posted: 10/12/21 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Northstar, Bigfoot and Northern Lite are some additional brands you should compare.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
Geo*Boy
Unknown
Posted: 10/12/21 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Is your truck a dually?
jimh425
Western MT
Posted: 10/12/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Probably not if his max is 4000 lbs.
I’d add Host to the list. Maybe not current models, but they also made small TCs and single slide models a few years ago.
* This post was edited 10/12/21 07:05pm by jimh425 *
StirCrazy
Posted: 10/13/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
No, thats why there is realy only one artic fox I could buy. the 856 is the one that I could carry. the others would be pushing my max a little to much. we realy do like the 992, but thatvputs us up around 4500 lbs which I dont know how crazy being 500 lbs over on a 14 F350 is (have the heavy payload option on it)? I know 20 years ago guys were hauling 5000lbs campers on trucks that were only rated for 3800 - 4500 lbs
Steve
Geo*Boy
Unknown
Posted: 10/13/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Steve, Northwoods recommends a dually for all their AF TC’s, you maybe ok with the 865 with minimal gear and empty tanks. I would definitely run a set of Timbren double convolutes as insurance and get a Roadmaster sway bar.
StirCrazy
Posted: 10/13/21 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
no with the heavy gvrw package of my truck if it is fully loaded to max I am 120lbs over my gvw including myself the dog and the wife. I have a couple friends that have that one on there SRW and no issues either, but ya I agree every other one I looked at just got heavier. a new truck may be in the books in 10 years but not now and I dont need the slides if it is a good unit.
as for the timberen's what are double convolutes? I had timberns on my old truck. and ya a rear sway bar is already on my radar.
Steve
Steve
mkirsch
Rochester, NY
Posted: 10/14/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
120 over gvwr is pretty good.
You'll find that it is quite common for folks in here to ignore gvwr and just use combined axle ratings. Some will even just say "rear axle is rated for 10,000 by its manufacturer so put bigger tires on it and pile it on."
Geo*Boy
Unknown
Posted: 10/14/21 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Steve
Steve
Timbren makes two kits, the severe duty kit and the regular, double convoluted, kit. Don’t use the severe kit.
Kayteg1
California > Nevada
Posted: 10/14/21 08:31am Link  |  Quote  |  Print  |  Notify Moderator
GVWR is taxable number and has very loose connection to truck capacities.
With TC rear axle weigh rating is the only that really matters.
Once you weigh it and read the label, you know what camper you can slide on it.
Obviously you will always find guys who go overboard and they apply dually axle capacity to SRW, just becouse the axle has the same model number.
But the same model number comes with different gears, different shafts and different bearings.
