RV.Net Open Roads Forum: Truck Campers: Looking for options
 > Looking for options
ICamel
Oregon
Posted: 10/14/21 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy wrote:
we realy do like the 992Steve
Going on 6 years with our 992 in a 2005 F350 SRW. To each their own[emoticon]
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
StirCrazy
Kamloops, BC, Canada
Posted: 10/14/21 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
did you modify anything?
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
sweeperman210
New Jersey
Posted: 10/14/21 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
my 2008 af 990 clocks in at 5200 lbs full water and propane
ICamel
Oregon
Posted: 10/15/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Steve
Per my signature "19.5" Tires + LoadLifter 5000 Rear Air Bags"
If I had to do it over again, I would go with "All Terrain" 19.5" tires instead of the "Highway" tread, as the Highway tread doesn't provide sufficient traction on wet ground.
greenno
Clairemont Cal.
Posted: 10/16/21 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Haulin my 2019 AF990 with a SWR rig to. 5100 lbs loaded up.
Got some mods on my rig. To each his own.
burningman
Seattle, WA USA
Posted: 10/20/21 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Every 3/4 or one-ton pickup out there will haul a 5000 pound camper.
It’s all about what your rear tires are good for.
Don’t believe camper weight specs, they’re 100% always unrealistically light.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Reality Check
North Bend
Posted: 10/20/21 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Wife and I love the 865... it's an awesome model. The kitchen, dinette in back, windows on three sides. It's open, bright. Just think it's an awesome unit.
I'd throw it on a 1 ton and go play.
'16 F550 CC, 4x4 with Link Ultraride air suspension, '18 AF 1150. Just so we can play with our snowmobiles, dirt bikes and fishing boat. And new 20' tag along...kayaks, bikes, mc's and extra water and food!!
StirCrazy
Posted: 10/21/21 08:47am Link  |  Quote  |  Print  |  Notify Moderator
mkirsch wrote:
120 over gvwr is pretty good.
You'll find that it is quite common for folks in here to ignore gvwr and just use combined axle ratings. Some will even just say "rear axle is rated for 10,000 by its manufacturer so put bigger tires on it and pile it on."
oh I know, and thats what I go by also. that and tire weight, but I also use front axel weight as some of the weight goes there also. I have 4K available on my rear and about 1000 on my front. GVW is nothing here unless you are a comercial truck, aside from determining how much regestration you'll pay....
Steve
StirCrazy
Posted: 10/21/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
oh ya the weight they list is 2641lbs, but then there is the mandatory option package weight of about 600 lbs so thats up to 3250ish now. take the weight of water, propane, food cloths and such and that fills up to about 4000ish.
Steve
StirCrazy
Posted: 10/21/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I did like the wrap around view of the back, we also have a puppy, well a 90 lb lab, so I liked the idead of a slide but we can live with out one.
Steve
