RV.Net Open Roads Forum: My water heater drain plug is metal, is that a problem?
 > My water heater drain plug is metal, is that a problem?
way2roll
Wilmington NC
Posted: 10/12/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
All former RV's I have had came with a plastic hot water drain plug. My new one is metal and it's rusting. I am going to drain it for the winter and wondering if I shouldn't replace it with a plastic one. Might even go further and get one with a valve built in. Thoughts?
momentum rv
Central Cal.
Posted: 10/12/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
It may be an anode rod depending on brand/interior construction.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
valhalla360
No paticular place.
Posted: 10/12/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
High probability, it is also the anode...you don't want to replace the anode with a plastic plug.
Something will corrode and if there is no anode, it's the tank.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
pinesman
virginia
Posted: 10/12/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Of the ones that I have seen, Atwood usually has a smaller plastic plug but Suburban has a larger metal one with an anode rod attached
way2roll
Wilmington NC
Posted: 10/12/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
I hadn't considered the anode - duh. [emoticon]
Thanks!
Dick_B
Palos Heights, IL USA
Posted: 10/12/21 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Might want to consider replacing the anode rod yearly with threads wrapped with teflon tape even tho the rod itself has plenty of life in it if it truly is rusting.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
way2roll
Wilmington NC
Posted: 10/12/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
It was installed with plenty of pipe tape but yes, better safe than sorry.
opnspaces
San Diego Ca
Posted: 10/12/21 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
what brand water heater? I believe all Atwoods use plastic with no anode and Suburban uses metal with an anode.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
larry barnhart
wenatchee. wa usa
Posted: 10/12/21 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
too many wraps is a bad thing to do with tape. Just need 1/12.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
on the road
Posted: 10/13/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
I use the Teflon thread sealant by Permatex in the squeeze tube. Can’t remember last time I used the tape.
I am on the same anode for five full time years still looks great. I pull it and flush out the tank once a year.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
