RV.Net Open Roads Forum: UPGRADE to a larger LP tank ?
 > UPGRADE to a larger LP tank ?
LandYacht35diesel
Florida STAYcation
Posted: 10/12/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
.....anyone ever do it ?
The ONE major complaint I have with this Airstream is the small tank. Can’t do much with the length ... but could probably go with something 6-8 inch larger in diameter...
dougrainer
Carrolton, Texas
Posted: 10/13/21 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Just get an extend a stay and then purchase a 100lb LP cylinder. Doug
https://www.campingworld.com/stay-longer........IfcDZDzRFIWOTRoCuBIQAvD_BwE&gclsrc=aw.ds
https://www.tractorsupply.com/tsc/produc........ical-lp-cylinder-equipped-with-pol-valve
LandYacht35diesel
Florida STAYcation
Posted: 10/15/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Doug .... how does that work rolling down the road ? NOW IF all I had to worry about was powering the frig and stove with LP .... no problem. But the gen is fueled by LP. And that consumes lots. Heating? .. don’t use that much at all but if you did ... you’d have to get the tank filled quite often !
Posted: 10/15/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
To use a larger tank (I'd suggest a 50 it is easier to carry)
You use the on board tank on the road
you use the "External" when parked.
Done that with my class A. it had a 100 pound on board (27 gallons) and I used 20 pounders when needed but.... It was nice when I could not get to ye old propane place.
Dutch_12078
Winters south, summers north
Posted: 10/15/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
In addition to our onboard 100 lb ASME tank, we carry a 30 lb DOT cylinder connected to an Extend-A-Stay fitting. Under way, the cylinder is secured in a ventilated storage bin with the Extend-A-Stay hose attached and active. Most of the time we only switch to the 100 lb tank until we can get the 30 lb cylinder refilled when it runs out. It's usually a lot easier to get the portable 30 lb refilled than the onboard 100 lb tank.
Dutch
2001 GBM Landau 34' Class A
dougrainer
Carrolton, Texas
Posted: 10/15/21 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
You have found the BIG problem when OEM's use LP powered Gensets versus spending the money on a Diesel genset on a Diesel powered Motorhome. Since your handle states Land Yacht, I will bet you have a 1990 to 1995 or so Land Yacht Diesel. Back then, Diesel RV Gensets were very expensive and OEM's installed LP powered Gensets to lower the cost. Also, some models of Diesel Motorhomes could not be configured with the size and design of that era Diesel Gensets. Some older Airstreams(1980 to about 1985) motorhomes, not Land Yachts, had 2 ASME LP tanks. A LARGE tank that held about 28 gallons liquid LP on the drivers side and a smaller tank about 10 gallons on the passenger side. The large tank powered the LP genset. FYI, these Airstreams used a Isuzu Diesel engine on a Chevy chassis. So, the Extend a stay ONLY works when camped. Then you have to have a way to safely transport the cylinder. ANY type ASME tank you will be able to find that will be larger will probably only increase your LP by at most 10 gallons. Not feasable for the cost. Doug
hohenwald48
Nashville, TN
Posted: 10/16/21 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
LP powered generators have caught a lot of diesel RV owners off guard. Manufacturers still opt for the cheaper installation unless the customer specifies a diesel generator. Especially in the smaller RV sizes.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
LandYacht35diesel
Florida STAYcation
Posted: 10/18/21 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thx guyz ..... what is the cost of that upgrade? Are there compact D gens now available ? I wouldn’t need anything as large as what LP gen is in there now.
dougrainer
Carrolton, Texas
Posted: 10/19/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
This is the current Onan small RV motorhome Diesel sets. Don't be fooled by when it states Gasoline half load. Doug
QD 3200
AIR CONDITION CAPACITY: One 13,500
DIMENSIONS: L 30.2” W 17.3” H 18.0”
WEIGHT: 205 lbs
FUEL CONSUMPTION:
GASOLINE HALF LOAD
0.40 Gal/h 0.30 Gal/h
LPG
QD 6000
AIR CONDITION CAPACITY: Two 15,000
DIMENSIONS: L 36.3” W 23.6” H 22.3”
WEIGHT: 420 lbs
FUEL CONSUMPTION:
GASOLINE HALF LOAD
0.70 Gal/h 0.40 Gal/h
LPG
QD 8000
WEIGHT: 420 lbs
FUEL CONSUMPTION:
GASOLINE HALF LOAD
1.02 Gal/h 0.49 Gal/
dougrainer
Carrolton, Texas
Posted: 10/19/21 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I will tell you, when a customer wanted to trade a Diesel Motorhome with a LP Genset, the trade was downgraded from 5k to 7k in price due to the LP genset. This is one upgrade that will help pay for itself. Doug
