RV.Net Open Roads Forum: Handling “hard dried stuff” in the black tank ?
 > Handling “hard dried stuff” in the black tank ?
LandYacht35diesel
Florida STAYcation
Posted: 10/12/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
..... anyway to SLOOOOWLY dissolve it and rinse it away ?
Lumpty
Greater Gotham City
Posted: 10/12/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Buy some ice, like at least 30 lbs worth. Dump it down the toilet into the black tank. Add a little water. Also pour down the hole a lot of liquid laundry detergent. Then, go for a spirited, bumpy and curvy road drive. Afterwards. let it sit for an hour or two, then dump. That should get all the petrified poop out.
Rob
Too Many Toys.
- '11 E450 Sunseeker 2300
- '16 F150 Supercrew 5.0/FX4
- '09 C6 Z51
- '15 VW Golf Sportwagen daily driver
- '86 Civic and '87 CRX race cars
mlpeloquin
San Jose, CA
Posted: 10/12/21 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
You can, if you have time, put a quart of home septic tank treatment in the tank with a quarter fill of water. Let it sit for two weeks and drive. You could add the ice and then drive, but all that enzyme treatment should have eaten it all up. Did this to a fully clogged tank and it was so clean the OEM tank level system worked for the next five trips like it did when new.
rgatijnet1
Posted: 10/13/21 05:27am Link  |  Quote  |  Print  |  Notify Moderator
If you can dump your tanks at your house, or a nearby location, just fill both the black and grey tanks, add some Rid-X and let them sit for several days. This will soften any debris and let it pass out the drain. You are in Florida so you do not have to worry about the tanks freezing while the Rid-X is doing it's thing.
Matt_Colie
Southeast Michigan
Posted: 10/13/21 08:57am Link  |  Quote  |  Print  |  Notify Moderator
There is a great YouTube "Ice in Black Tank". I suggest you make note of his test and success before you proceed.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog (one is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
dougrainer
Carrolton, Texas
Posted: 10/13/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
I guess you learned your lesson the Hard way[emoticon] You either are full time and leave the black and gray tank valves open or when camped you also left the valves open. NEVER EVER DO THAT. Look up Poop Pyramid in google. I would shut the tank valve boil as much water as possible and pour that hot water with the rid x. Try to get at least 20 gallons of hot water and let sit for a few days. Hopefully that will break up the poop and get it into suspension to then drain out and flush. Doug
RLS7201
Posted: 10/13/21 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
If your commode sits over the black tank, there are wands that are designed to attach to a garden hose with a small hole drilled in the side of the bottom end. This will blow away the pile of poop.
Poop Blaster
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
valhalla360
No paticular place.
Posted: 10/13/21 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Unless it's the dreaded pyramid of poo...just don't worry about it.
Use plenty of water when camping and worry about the beer getting warm. Magic elixirs don't break it down any faster and the next deposit and it will no longer be sanitary.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
pianotuna
Regina, SK, Canada
Posted: 10/13/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
ice does just about nothing.
Hot water calgon dishwasher soap and time.
Regards, Don
Brandon the Traveler
SC, NY, PA, WV
Posted: 10/14/21 06:10am Link  |  Quote  |  Print  |  Notify Moderator
Why not dump 20 gallons of boiling water and a $10 bill down the turlet? The hot water will kill off the bacteria in the rid X, which is @ $10 a box, and even when active without boiling it to death will do nothing in something with a small volume such as an RV HOLDING tank. May as well use the $10 bill and save the cost and time of running out to buy the rid-X.
I went.
