navigator2346
Wa and points South
You didn't say if you are going to carry it or leave it on the patio. If going to carry, then the Green Mountain Davey Crockett can't be beat. If you are leaving it on the patio, a Yoder would be my choice assuming that money is no object.
propchef
NORCAL
No budget?
Cookshack. https://cookshack.com/residential-smokers-grills/
We have one and it's been problem-free for ten years now. It's small but mighty. You'll find it's a tank compared to the Masterbuilt.
Super_Dave
Harrisville, UT
FYI, the Green Mountain Davey Crockett model has been replaced by the Trek model. They no longer make the Davey Crockett. The only difference between the two is they changed the legs.
If you want a high end smoker and have looked at the Cookshack and SmokinTex, the Smokin-It is comparable at a much better price point.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
magnusfide
On the Road Again and Again and Again...
Super_Dave wrote: FYI, the Green Mountain Davey Crockett model has been replaced by the Trek model. They no longer make the Davey Crockett. The only difference between the two is they changed the legs.
Super Dave, great to see you on the board again. Of the three smokers (Cookshack, SmokinTex and Smokin-It) which are made in the USA?
"The only time you should fear cast iron is if your wife is fixin' to hit you with it."-Kent Rollins
First law of science: don't spit into the wind.
Magnus
CA Traveler
The Western States
Super_Dave wrote: FYI, the Green Mountain Davey Crockett model has been replaced by the Trek model. They no longer make the Davey Crockett. The only difference between the two is they changed the legs. Thanks for that update. Unfortunately those longer legs would not work for me - see photo in my post above - because the additional height would not fit in the RV. Perhaps they can be removed.
I've used mine as shown in the photo, on a table top with its short spring legs and on the ground with the folding legs.
As a FYI I did cut off 1.5" of the chimney so that it would fit in the MH.
2014 Grand Cherokee Overland
Bob
Super_Dave
Harrisville, UT
I can't speak to Cookshack and SmokinTex but possibly excluding some electronic parts, my Smokin-It was US made.
