RV.Net Open Roads Forum: Class C Motorhomes: Winterizing
 > Winterizing
phil leach
Merritt
Posted: 10/13/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
I recently bought a 2008 Winnebago 29B and am curious about how to winterize it.
bobndot
Posted: 10/13/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Its a lot easier to look at general YouTube videos for the procedure, than trying to explain it in detail.
Then we can help with specific questions you might have.
Mfan
Otsego,Mi
Posted: 10/13/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Easy way...park in a heated garage.
Empty your holding tanks, drain the fresh water out,including the water heater. Run pink antifreeze through the lines, in the sink traps, and dump the rest in the holding tanks.
Near DVNP, California
Posted: 10/13/21 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Keep your batteries fully charged if they aren’t lithium.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
whemme
Spencer, IA
Posted: 10/13/21 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Read the owner’s manual!
2002 Born Free 26' RSB Motorcoach
2005 Chevrolet Malibu LS Toad
SDcampowneroperator
South Dakota
Posted: 10/13/21 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Every type of. RV has a best winterizing method. Compressed air and the pumped glycol A/F are both effective, it depends on access to compessed air and the water systems in your RV. I've winterized dozens of every type.
To pump the 'pink' as its known, you have to have a way to switch suction from your fresh water tank to a hose that drars from the 'pink ' gallon' jug.
We had 2 rigs from the 70-80s that did not hava a 2 way valve, so to switch from the tank to the suction hose for the pink was a simple wrench job, the suction from the tank a different hose for A/F or compressed air.
Whatever your unit is, drain and bypass the cold water heater, it may be 1 - 3 position valve or 3 on the inside, then remove the drain plug outside.
Then hook up your air compressor set to no more than 60 psi output or put a hose in the jug of pink. then go around, nearest to farthest 2 times around to get the pink or air with some mist only.
It it really simpe, learn your unit, think it thruugh
Beverley&Ken
Tottenham,Ontario
Posted: 10/13/21 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Your 08 is probably the same as our 06 29B. 2nd compartment behind the drivers door is the compartment. There is a shelf at the back of the compartment, actually over the Ford frame rail, a little hard to see with out getting on your hands and knees. At the front is the fresh water tank drain valve, large yellow handle, 90 degree open or closed. Then there is the water pump and then the winterizing line. It could be curled up and partially hidden, it's attached to the water line between the fresh water tank (which is the very back wall of that space) connected with a two way valve, pump either draws from the tank or your winterizing jug. Further back you will see another two way valve which is the low point drain for the lines on the drivers side.
On the passenger side, first compartment behind the rear wheels there are two vertical lines on the back wall of the compartment, which is directly below your shower. They have shut off valves in them, they are your hot and cold low point drains. they are open ended and terminal just below the compartment floor.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
rr2254545
Central Minnesota
Posted: 10/14/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Your owner manual is on line
https://www.winnebago.com/owners/owner-resources/manuals-and-diagrams/operator-manuals/2008
Gives you step by step instructions for the process
* This post was edited 10/14/21 06:00pm by rr2254545 *
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee, Air Force One, Blue Ox Avail tow bar
405 Campgrounds,91K miles driven in our Winnebago motor homes and 1961 nights camping since we retired in July 2009
Timmo!
South-central Oregon...on the river
Posted: 10/14/21 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Some of us use "pink" and some of us don't.
The goal key is remove all water from the lines, water heater, expansion tank and fresh water tank. Air pressure works and so does gravity.
bobndot
Posted: 10/14/21 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
BTW, its important to know, winterizing an average rv takes about 2 gals of antifreeze.
If you find that you’re pumping 4-5 gals into your system, then your bypass valves are still open allowing your water heater to fill.
Think of it as a 6 gal thermos bottle with a cold water fill port and hot water out port. The idea of the bypass is to join your water lines by using petcock valves to bypass the WH.
After draining the WH , it’s ok to leave a small amount of water in the bottom of the tank, it won’t harm anything if it freezes.
Todays Pex lines are very forgiving, it’s the plastic inline elbows and petcocks that freeze and crack.
 > Winterizing
