JTMills
Spokane, WA
Hi all, just bought a used trailer so we r brand new to owning an RV. A 2011 Milan Eclipse to be exact. Anyway, the light-up flame electric fireplace, which is very pleasing to look at, won’t turn on. My wife is going to kill me because it was one ‘must have’ for allowing me to buy it. It came with an extra bulb, but I can’t get it to do anything when I turn it on. Any recommendations? Is there reset buttons, a fuse inside, or anything else that isn’t in plain site?
edited 10/13/21 09:04pm by JTMills *
Flute Man
Payson, Arizona
Do you have power going to it either 12 V or 120? Did it work before?
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
JTMills
Spokane, WA
Jerry, thanks. Yes, I have it plugged into an outlet right now, at our house, as well as having 2 brand new deep cycle batteries installed. The owner told me it was electric only, as opposed to propane.
JTMills
Spokane, WA
Jerry, I bought it without trying it out so Im not sure if it worked before or not and this is why my wife may kill me.
time2roll
Call the seller and ask if you have it set up right.
675w Solar pictures back up
BluegrassBill
Woodland, Wa. USA
You have a circuit breaker panel, Check for a tripped breaker.
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
cgjt
western new york
Look by the control panel for a switch. Some campers with30 amp service have a switch that switches the power from the air conditioner to the fireplace preventing both from running at the same time and not overloading the circuit breaker. Hope this helps.
blawless
Killaloe, Ontario
Hi, you didn't give us the name brand of the fireplace. Generally there is a built-in safety circuit that prevents the unit from turning on if the fan area is too dusty restricting air flow. Take a vacuum and clean the back of the unit. And if equipped with a filter,clean that as well. Hopefully it should work again.
Retired and enjoying it!
2005 Coachmen Aurora 3380 MBS Class A F53 V10 Banks Power System.
2014 Jeep Compass Toad
2001 Fleetwood Prowler 255B 5th wheel
2003 F150 King Ranch Supercrew 4X4
ReneeG
Meridian, Idaho
The brand will help. Ours has two buttons on opposite sides, on the bottom under a flap. The fan must be on before the fireplace heater and light will turn on.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
JKJavelin
Milwaukee, WI
Google rv fireplace or search on Ebay. Check the dimensions and look at the pics, they are only $100+
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
2021- 122 Nights
2022- 85 Nights
