RV.Net Open Roads Forum: My wife is gonna kill me, please help
 > My wife is gonna kill me, please help
Page of 7
joshuajim
Mojave Desert
Posted: 10/14/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I’m sorry that your wife is going to kill you [emoticon]. I can’t help because that would be illegal, but I know someone she can call for help [emoticon]
RVing since 1995.
RedRollingRoadblock
Oregon
Posted: 10/14/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Millions of other wives?
mgirardo
Brunswick, GA
Posted: 10/14/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
JTMills wrote:
Jerry, thanks. Yes, I have it plugged into an outlet right now, at our house, as well as having 2 brand new deep cycle batteries installed. The owner told me it was electric only, as opposed to propane.
Since the previous owner says it is electric only, most likely it requires 110v.
Unless you have an inverter that powers the outlet you have the fireplace plugged into, the trailer needs to be plugged into Shore Power? If you do have an inverter powering the outlet, does it offer enough watts? Electric fireplaces usually require around 1500 watts.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
MFL
Midwest
Posted: 10/14/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Do all other electric outlets/appliances work? Do you have a meter, to check power coming to unit?
Husband may already be dead, as it appears WIFE Tami, was the one joining forum, and posting??
Jerry
Sandia Man
Rio Rancho, NM
Posted: 10/14/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Just take it apart and visually inspect it if you have already plugged it into a reliable outlet in your home, remove from power source before disassembly. Otherwise just chuck it in the trash and get a better quality unit from Wallys or Amazon delivered in 2-3 days, after 10 years of bouncing around it may be a safety hazard anyway.
With colder temps upon us I recently had to get our electric space heaters ready, had to replace our decades old space heater as it would not turn on as well. Didn't see anything visually wrong, control board probably took a hit and quickly tossed it and picked up a vastly better version.
shastagary
minnesota
Posted: 10/14/21 11:42am Link  |  Quote  |  Print  |  Notify Moderator
look for the tag showing who made it and the model number do a google search for the manual for it so you know how to work it some of them came with a remote control to operate it.
how do you set the temperature on it?
its just a electric heater with a light display that looks like a fire
Quartzsite, AZ
Posted: 10/14/21 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Please let us know where to send flowers prior to your demise.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
dedmiston
The West
Posted: 10/14/21 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Our electric fireplace only works with the generator running or shore power plugged in. It definitely won't run from the 12v batteries or inverter.
I agree that it's worth asking the seller.
Also check fuses and breakers.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
MFL
Midwest
Posted: 10/14/21 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
OP replied in 2nd post "he/she is plugged into house outlet right now". So unless home breaker tripped, 120 AC should be available.
An older 15A circuit may not handle the wattage of the fireplace for a lengthy time.
If meter shows current to fireplace hookup source, the fireplace may have expired.
Jerry
JTMills
Spokane, WA
Posted: 10/14/21 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
All, the fireplace is a “Little Prince” 66000 DLP-79
Page of 7
