John Wayne
Long Beach, Ca
Check to see if you have a gfi plug that may have tripped. Can you see where it plugs in if so just plug a 110 volt light into the socket to make sure you have power to the plug.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
toedtoes
California
I did a quick search on the model and found three facebook posts stating that the fireplace wasn't working. One poster stated that he had to turn on a separate fan and blow it directly into the bottom vent to get it to run on the low setting. It would not run on the high setting at all.
I think for a couple hundred dollars, you'd be better off just buying a newer better quality fireplace.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
You are plugged into the house
is the outlet's breaker popped?
Is the outlet a GFCI?
Any breakers in the RV tripped
If the fireplace plugs in is it Plug - - Outlet or plug=outlet (Plug out of outlet)
DO you have ether a Multi-Meter or at the very least a 3-light outlet tester
If not get a multi Meter and learn how to use it
Also get a 3-light outlet tester and a 15-30 Puck adapter so you can plug the 3LT into a 30 amp outlet (Before you plug in the RV) learn the meaning of the 3 lights (GREEN-Green GOOD.. Green-Red bad is a general rule GREEN Dark Dark also bad)
These are the basics.
Now the next level
Does it operate off on/off buttons or a turn the dial Thermostat on the unit or via an Infrared Remote..
If Remote: Dead battery in remote or plastic strip still in placew
Both Fluorescent and some LED lights will mess up I/R reomtes. Turn all lights off and try then turn them back on (This is far down the list but happens)
After that it's seek help I fear.
ken56
Tennessee
I had a trailer that had an electric fireplace that had a switch I had to flip to use it because you couldn't use the furnace AND the fireplace at the same time....it was one or the other. You might look for a switch near the floor or near your electric panel.
Boon Docker
This thread is pretty funny.
People are still telling the OP to check things in the trailer.
Even after the OP indicated that the fireplace was plugged into an outlet in the house and still wouldn't work.
toedtoes
California
Boon Docker wrote: This thread is pretty funny.
Even after the OP indicated that the fireplace was plugged into an outlet in the house and still wouldn't work. ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
Here's the comment:
Jerry, thanks. Yes, I have it plugged into an outlet right now, at our house, as well as having 2 brand new deep cycle batteries installed. The owner told me it was electric only, as opposed to propane.
It's not real clear as to it referring to the fireplace being plugged into an outlet or the RV being plugged into the outlet. That they mentioned having 2 new batteries in the same sentence suggests to me that they are saying the RV is plugged into an outlet at their house.
bikendan
Goodyear, Arizona
ken56 wrote: I had a trailer that had an electric fireplace that had a switch I had to flip to use it because you couldn't use the furnace AND the fireplace at the same time....it was one or the other. You might look for a switch near the floor or near your electric panel.
I thought some had a fireplace or microwave switch.
Furnace runs on 12v DC, not like the 110v AC for the fireplace.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Boon Docker
toedtoes wrote: Boon Docker wrote: This thread is pretty funny.
Here's the comment:
The question just previous to that reply was: "Do you have power going to it either 12 V or 120?"
To me the OP response to that question was pretty obvious that it was the fireplace that was plugged in.
JTMills
Spokane, WA
I see the reason for some to giggle at our/my thread. I mentoned I am new to RVing. The RV is plugged into our home outlet/110. I am extremely busy during the week and have no idea how to keep up with all of your suggestions and advice. I don’t have a power tester, but as per one of yous tips, I will pock one up when I have cash. Using my debit card, that my wife watches like a hawk, is not wise at this time. We all know why. She is suspicious. Suspicious as to why I won’t show her our pretty fireplace. Excuses are running out. Not to mention, She set up this account so I could ‘learn’ from others.....and learning from others I am. However, I have much to learn (obviously, as my need to ask in this way) and need to set time aside to delve into this RV when ‘she’ is not home so I can work without the pressure.
The not so funny part is that she could probably fix it if I told her. Im just not yet willing to freely go to the doghouse myself, yet. Thanks for standing with me to this point. Update to follow soon.
FYI, I cannot find my “Little Prince” fireplace in a simple google search.....which is perplexing to say the least.
toedtoes
California
Boon Docker wrote: toedtoes wrote: Boon Docker wrote: This thread is pretty funny.
Here's the comment:
To me the OP response to that question was pretty obvious that it was the fireplace that was plugged in. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
JTMills wrote: The RV is plugged into our home outlet/110.
