RV.Net Open Roads Forum: Truck Campers: Host, Eagle Cap, Lance Suspension Requirements
 > Host, Eagle Cap, Lance Suspension Requirements
wjlapier
Washington
Posted: 10/14/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
So, for now in our initial search we have narrowed it down to these three truck camper companies. We’ve talked and talked about why we would go from a Grand Design Imagine 2500RL TT to a truck camper. My wife wants the space the Lance 1172 provides. What we have been told is we would need to modify the suspension and tires. And wheels? Extra cost on top of the price of the camper and trading in the Imagine.
What is needed to be done for a 2019 Silverado 3500HD DRW truck to carry the 1172? I’ve been told nothing needs to be done to our truck for the Host Cascade. I haven’t heard anything yet regarding the big Eagle Cap campers.
Thank for any info you can share.
2017 GMC Sierra Denali 3500 HD Duramax
2019 Grand Design Imagine 2600RB
toddb
az
Posted: 10/14/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Skip the band aids and go to kelderman.
Posted: 10/14/21 09:12am Link  |  Quote  |  Print  |  Notify Moderator
And you’re buying? Lol.
2017 Heartland Torque T29
Posted: 10/14/21 09:17am Link  |  Quote  |  Print  |  Notify Moderator
OP, you can safely haul virtually any factory TC out there with judicious to normal loading of gear and provisions with any new dually pickup with minimal modifications.
(Qualified for the overtly literal members here who will refute based on hauling rock collections or such and then saying how it’s unsafe to haul a 7500 lb camper (with 500 lbs of rocks and 1000 lbs of extra gear)
You WILL need some suspension help though.
Tires/wheels/axle/chassis is good for any easy 6000, maybe 6500lbs.
But a big rear sway bar is recommended and your choice of helpers for the springs will be necessary to take some of the compression out of the springs
brain
Muscatine, IA
Posted: 10/14/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Can't argue the Kelderman plug, but it's pricey, I know :-)
When we first pushed the OK117DBL onto the F350, we had good luck with Timbrens and some bump stop extenders. Those are cheapest and I'd try them first.
And a rear sway bar, as noted.
Jim
JIMNLIN
Oklahoma
Posted: 10/14/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
GM gives that year model truck a 9350?? rawr for carrying weight in the bed. These trucks rear axle may weigh in the 3400 lb range for approx 6000 lb in the bed payload.
You have the truck so drop by your local CAT scales at a truck stop and get your trucks separate front and rear axle weights with close attention to rear axle weights as its carrying just about all the TC.....That way you know how much truck camper your particular 3500 DRW can carry.
I wouldn't do a thing to the truck before adding a truck camper and make a short local trip. Then is the time to decide if suspension help is needed.
markowwes
Vegreville, Ab. Canada
Posted: 10/14/21 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Yup
reddrum
Central NC
Posted: 10/14/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
You will want a rear sway bar for sure. Shocks would be nice as well. Air bags or something fancier are that much better. Go weigh the truck and subtract that from GVWR to get your payload. Well worth the time to do. Then sort through the TCs weights. I have an Eagle Cap 1160 on a 3500 with sway bar, shocks, and air bags. It has been to 48 states over the years. Great truck and camper.
Kayteg1
California > Nevada
Posted: 10/14/21 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Beware about forum agendas, who will lead you into buying something you might not need.
Check the PM.
mellow
Salisbury, MD
Posted: 10/15/21 07:38am Link  |  Quote  |  Print  |  Notify Moderator
And with the stock tires your can still air them down for fishing on the beach!
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
