RV.Net Open Roads Forum: Truck Campers: Host, Eagle Cap, Lance Suspension Requirements
 > Host, Eagle Cap, Lance Suspension Requirements
mkirsch
Rochester, NY
Posted: 10/15/21 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Here's the deal, there's no "magic" involved. It's all about weight. If one camper weighs 5000lbs and another camper weighs 5000lbs, one camper is not going to need suspension upgrades while the other one does.
Lance 1172 vs Host Cascade, they are not even close to the same camper. The Host is a smaller lighter camper by almost 800lbs.
Regardless of what you buy, it is not going to create a dangerous situation out of the box. You can load it at the dealer, take it home, even take it on a trip or two, and figure out what suspension modifications you need. Don't try to guess at what you might need. All the suspension mods do is level out your truck.
toddb
az
Posted: 10/15/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
toddb wrote:
Skip the band aids and go to kelderman.
And you’re buying? Lol.
I already did [emoticon]
wjlapier
Washington
Posted: 10/29/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
We ordered the Host Everest. Due for delivery April 2022. For now, we will have the Torklift tie downs installed with stableloads. Drive home ( over Snoqualmie Pass ) and see if we need anything else.
Our trips are mainly to the Tucannon area, the St Joe River in Idaho, and Babb, Montana.
2017 GMC Sierra Denali 3500 HD Duramax
2019 Grand Design Imagine 2600RB
Posted: 10/29/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I’m sure the OP is very grateful for your gesture…
2017 Heartland Torque T29
Posted: 10/29/21 11:04am Link  |  Quote  |  Print  |  Notify Moderator
May as well get a big sway bar while your at it.
Go put 2 pallets of bricks in the back and see how much it sags. Bout the same weight as the camper, except the campers center of gravity will be considerably higher. Same amount of dead load compression. A lot more live load body roll.
Geo*Boy
Unknown
Posted: 10/29/21 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Going to need the sway bar and a whole lot more to carry the Everest comfortably/safely.
