RV.Net Open Roads Forum: Travel Trailers: Winterizing
 > Winterizing
tomb48
NorthEast
Posted: 10/14/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Winterized my travel trailer last November. Due to health reasons, I was unable to use my trailer this season. Wondering if the antifreeze will be good for another Winter, or should I flush the system & replace the antifreeze. Opinions??
pianotuna
Regina, SK, Canada
Posted: 10/14/21 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I would add some to the traps.
Regards, Don
MFL
Midwest
Posted: 10/14/21 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Good quality anti-freeze? I'd not worry about it, but cheaper ethanol based AF is likely to evaporate. In that case, I'd dump more in the drains to fill the P-traps, to ensure no smell comes up from gray tanks.
Jerry
kellem
Shenandoah valley,VA
Posted: 10/15/21 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I'd say your good. Maybe fill the traps and.....don't let your toilet seal go dry.
hohenwald48
Nashville, TN
Posted: 10/17/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
New anti-freeze is pretty cheap and easy compared to a bunch of busted plumbing.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
HereWeGoJoe
Alberta
Posted: 10/17/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Winterised ours in 2019, and never used at all due to pandemic in 2020. So lasted 2 years. This year only used in our province for 12 nights sadly so we didn't dewinterise the washer/dryer. All was well for the 2 years but this year we did run more antifreeze (year 3) through the washer as well of course winterise everything else and pour down pee traps.
Put plenty in your toilet for the seal and cover the bowl with Saran Wrap to avoid drying out too quickly, and all should be good. If you feel uncomfortable though just flush through with more AF this year and of course all U bends/traps.
Boon Docker
Posted: 10/17/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
If you have the means to blow the lines out with air, do it and leave it that way. Just pour some more antifreeze in the p-traps and toilet.
 > Winterizing
