RV.Net Open Roads Forum: Fifth-Wheels: 2 cycle oil Dodge 5.9 diesel
 > 2 cycle oil Dodge 5.9 diesel
mikewats
Marietta Ga.
Posted: 10/15/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone add 2 cycle oil to their diesel fuel? Pro’s and con’s.
Thanks
Mikewats
06 Dodge 3500DRW-5.9 Banks Econo-tuner, High Ram intake, Ram Air Intake Sys.
2011 Carriage Cameo 36 FWS, 17.5 Michelin
laknox
Arizona
Posted: 10/15/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
I'd much rather run something that's more tailored for that, like Lucas Upper Cylinder Lube.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
rhagfo
Portland, OR
Posted: 10/15/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
In our old 5.9 we use Opti-Lube XPD additive, 1/2 oz per gallon of fuel.
Cummins12V98
on the road
Posted: 10/15/21 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Outboard 2 cycle the basic stuff is perfectly fine to add to the pre 07.5 Cummins engines. Heck a quart per tank of your used engine oil is perfectly fine also.
They are called "Oil Burner" for a reason!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
M.R.E.
MI, usa
Posted: 10/15/21 11:45am Link  |  Quote  |  Print  |  Notify Moderator
When I had my 7.3 , I used the recommended Two stroke that stated it had TC-W3.It was rated great for lubricity which the current diesel fuel doesn't have. All older diesels should use this.
toolmaker
fj12ryder
Platte City, MO
Posted: 10/15/21 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, never have. Thought about it, but never did it.
Howard and Peggy
"Don't Panic"
Diamond c
West ky
Posted: 10/15/21 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
I used to know a man that would add a qt of cheep oil to the tank of a gas burner once a month.
noteven
Turtle Island
Posted: 10/15/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
2 cycle oil is designed to burn as cleanly as possible. It shouldn’t hurt a diesel in moderation.
I’m not sure how it likes being compressed to 35000 psi’s in a common rail fuel system.
The manual for my old mechanical diesel Land Cruiser says emergency fuel can be made from 3 parts gasoline to 1 part 30 weight engine oil if necessary. It was built before the internet so that could be danger danger now.
memtb
Wyoming
Posted: 10/15/21 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
I put a pint in with every fill up in my 2007 6.7!
I read on a diesel forum, where an extensive test was performed using many fuel additives and conventional 2 cycle oil. The 2 cycle oil fished in 2nd place to a high dollar additive. I can’t swear that it helps.....but, I bet it doesn’t hurt!
In fact, as embarrassing as it is to admit this. About 3 years ago, I had my head placed securely where the sun doesn’t shine, and in almost 30 years of driving diesels.....I finally put gasoline in my diesel truck. I didn’t realize what I had done until it was full. About 27 gallons of gasoline in a 34 gallon fuel tank! 19 miles to my house, drain fuel tank, put a few gallons of diesel with a gallon of 2 cycle oil in tank and flushed system to injectors. Drive to town, fill tank with diesel this time! About 40K miles later.....she’s still doing OK. I can’t help but wonder if that little bit of 2 cycle oil added may have helped some! memtb
* This post was edited 10/15/21 08:52pm by memtb *
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Cummins12V98
on the road
Posted: 10/15/21 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Modern as in 07.5 and newer is no bueno!!! Won’t hurt the engine but sure will the downstream emissions systems.
