RV.Net Open Roads Forum: Generator runs fine, but no electricity in coach
 > Generator runs fine, but no electricity in coach
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 10/16/21 12:07am Link  |  Quote  |  Print  |  Notify Moderator
I can hope there is a responsible You Tube tutorial about how to use your meter. Do not guess.
Also, I highly recommend using nitrile mechanic's gloves when working around live circuits. They will protect against 120vac shock if dry.
Also folks with Pacemakers should not work on generators. The reality is not a failure of the Pacemaker. It's vulnerability is corrupted memory that can erroneously show fibrillation, Bradycardia, or even Infarction when your cardiologist retrieves data.
Bobbo
Wherever I park
Posted: 10/16/21 07:56am Link  |  Quote  |  Print  |  Notify Moderator
A cheap 3 light tester will tell you if the generator is putting out power, no knowledge needed. Just plug it in. If you have a bonded neutral, then two lights should light up. If you have a floating neutral, then one, and only one, light should light up. Both of those are normal results and show the generator is putting out power. (A floating neutral is reported by this device as an "OPEN GROUND.")
Bobbo and Lin
Janss
Sedona, AZ
Posted: 10/17/21 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
It'll be a few days until I can work on this again. So I may be back. I appreciate all the original and additional information.
I will flip the generator and in coach circuit breakers off and on again, even though I had already done that to begin with.
No pacemakers here, but thanks for the warning.
Bobbo...I wouldn't know where to plug that tester in. My generator and shore power are hardwired to the automatic transfer box.
I know that there is no power inside the coach. The power management panel is not indicating that generator power is coming in while the gennie is running. I need to determine if the generator is not producing power or the automatic transfer switch is not working. I do not know exactly how to check these things. I may end up hiring an RV tech or electrician.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
Bobbo
Wherever I park
Posted: 10/17/21 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry about that. I thought it was a portable generator. If you can get to the wires going from the generator to the ATS, you can use a Non Contact Voltage Tester. Touching the tip to the insulation over the hot wire makes it light up/beep. Touching the tip to the neutral or ground wire does not. If you can get to the wire, touch the tip to all sides of the wire.
bounder39zman
SC
Posted: 10/19/21 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
If this model of Onan continues to run, then it is making power. Assuming circuit breakers are on (and good), then most likely problem is wiring connections in connection box (usually near genset itself), or in transfer switch. I've found most transfer switch problems to be in the time-delay circuit board in x-fer sw. It can often be by-passed with a small dip switch on circuit board. (The switch will engage on generator power, but no time delay)
