RV.Net Open Roads Forum: Propane tank cover modification
 > Propane tank cover modification
enahs
Washington
Posted: 10/15/21 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
New style dual tank regulators have a status view window on the front as opposed to the top. This makes it difficult to check the status of the tanks if a switch over has occurred without pulling the plastic cover off. Of course, you can cut a hole in the front of the plastic cover and install a plexiglass piece to serve as a window, but I am wondering whether there is a nifty commercial item that would do the job. I've seen a commercial portal used, but I have no idea where it came from and searches have turned up nuttin. Any ideas.
'07 Chevy 3500 Dooley, CC, LT3, D/A
Ltrip
Reno, NV
Posted: 10/15/21 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
I find it is easiest to simply take the whole cover off, and put it back on.
Mine slips off and onn very easily.
Larie Trippet Reno/Tahoe region
2018 Ford F250 Lariat Ultimate CC SB 4X4 diesel
2018 Arctic Fox 25Y
2019 BMW R1250RT
Brandon the Traveler
SC, NY, PA, WV
Posted: 10/15/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
No need to make something uncomplicated, complicated. Just take a 1-1/2" hole saw and punch a hole thru directly in front of the indicator. Why would you need to put plexiglass over it, the cover seams and lid are far from waterproof without the hole. No gadgets required.
I went.
toedtoes
California
Posted: 10/15/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
For my trailer, I installed two of these hatches. One over each tank. It makes it really easy to check the gauges and open and close the valves. I like these because they have a pull tab rather than just a couple indents to unscrew thwm.
They've never leaked.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Posted: 10/16/21 11:03am Link  |  Quote  |  Print  |  Notify Moderator
I always wonder how often folks check their propane levels….
In winter camping it gets used pretty quick, but aside from that, even shoulder season where one might use the furnace a little at night, it lasts a long time.
And my cover literally takes 2 Seconds to remove maybe I don’t have a difficult enough cover?
2017 Heartland Torque T29
SC, NY, PA, WV
Posted: 10/16/21 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
The OP has the indicator on the regulator assembly that faces the front. Looking at it from the top down will tell you nothing. Sure you could spend $25 installing one of those waterproof hatch covers but what is the point. The tank cover itself is made in 2 halves and is riveted together with no sealant or gaskers. It's not watertight nor is it supposed to be.
toedtoes
California
Posted: 10/16/21 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
You can install the hatch on the front.
As for why, the OP asked for ideas. If he likes this idea he can use it, if not he can ignore it. It's his choice to make not yours.
prichardson
Lafayette, La
Posted: 10/17/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
As said cut a hole in the front. If you don't like the idea of an open hole; make a cover with a piece of plastic a little larger than the hole and attach with one pop rivet above the hole. Now you have a little door to swing open and see the indicator.
philh
Belleville MI
Posted: 10/17/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
i put a 3" hole on the back side
SC, NY, PA, WV
Posted: 10/18/21 02:23am Link  |  Quote  |  Print  |  Notify Moderator
How does that work if the indicator on the change over regulator faces the front?
