RV.Net Open Roads Forum: F53 460 Engine runs very poorly when heat soaked
 > F53 460 Engine runs very poorly when heat soaked
Dutch_12078
Winters south, summers north
Posted: 10/16/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Sounds like it could be bad catalytic converter
The '95-'97 F53's didn't have a cat. Wasn't required...
Dutch
2001 GBM Landau 34' Class A
enblethen
Moses Lake, WA
Posted: 10/16/21 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
All vehicles that were built for MHs were built to meet California emissions.
Only way for OP to know is to look at his.
My "93 has a cat
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MT BOB
Montana
Posted: 10/17/21 04:26am Link  |  Quote  |  Print  |  Notify Moderator
My "93 has a cat
"All F53 from 1988 to 1993 had converters. Due to cylinder head redesign and altered state of tune, all F53 from 1994 to 1997 did not have converters and met 50 states emissions requirements. The resonator on 1994 to 1997 F53 is some times mistaken for a converter. No 1998 model year F53 chassis. All F53 from 1999 to present have converters. No exceptions were made for CA."
Twomed
FL winters and then somewhere cool
Posted: 10/17/21 06:41am Link  |  Quote  |  Print  |  Notify Moderator
460 in motorhome applications was pretty famous for this. Cheap easy fix (fingers crossed for you) was to insulate the the fuel line from fuel pump to the carb. An insulating fiber riser spacer between carb and manifold could help too.
Happy Trails ">
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
MT BOB
Montana
Posted: 10/17/21 06:48am Link  |  Quote  |  Print  |  Notify Moderator
There is no carb on a 95.
enblethen
Moses Lake, WA
Posted: 10/17/21 07:38am Link  |  Quote  |  Print  |  Notify Moderator
I would suggest that the OP physically look under his/her coach for a catalytic converter.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 10/17/21 10:34am Link  |  Quote  |  Print  |  Notify Moderator
And the Check Engine Light stays unlit?
pilotanpia
North Idaho
Posted: 10/17/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
My F53 Motorhome is 17,000 lbs GVWR. So, no catalytic converter installed from factory. I even confirmed this myself.
* This post was edited 10/17/21 11:42am by pilotanpia *
Donald L.
pilotanpia
North Idaho
Posted: 10/17/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
YES. No check engine light. The CI light did come on 4 years ago when the fuel pump failed. It comes on briefly when starting then goes off once engine is running. (Normal)
RLS7201
Posted: 10/17/21 11:50am Link  |  Quote  |  Print  |  Notify Moderator
My "93 has a cat
In 94 Ford changed cylinder heads and the state of tune which allowed the elimination of the cat to the end run of the 460 in 97.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
