RV.Net Open Roads Forum: Fifth-Wheels: Residential fridge
 > Residential fridge
Cummins12V98
on the road
Posted: 10/19/21 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I check water level every three months on my two 6V Interstate batteries. I add very little and I am in warm to HOT climates year round.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
austinjenna
Columbus, Ohio
Posted: 10/24/21 06:06am Link  |  Quote  |  Print  |  Notify Moderator
How long (approximately) will a residential run on 2 golf cart batteries? I am used to going to the rv lot the night before we leave and start the fridge on propane now, so it can be 17-20 hrs before I bring it back home. I dont think the batteries would last that long.
I know there are a lot of variables but looking for an approximation
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
JRscooby
Indepmo
Posted: 10/24/21 06:51am Link  |  Quote  |  Print  |  Notify Moderator
How long does it take the fridge in your house need to cool down?
I bet if you turned it on when you hooked up to bring it home by the time you got everything else loaded the fridge would be ready to pack.
MNRon
Tennessee
Posted: 10/24/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Austinjenna - a quick reply to your question: our residential fridge (and 1k inverter) draws 160A over 24hrs. Remember that for lead acid batteries you only want to draw down about 50% before recharging. Therefore assuming your golf cart batteries give you about 200AHr, you get about 100AHrs or 100/240= 10hrs running the fridge without other loads. If you’re driving you probably get 2-3A/hr charging from your truck so that you’re good for going site to site. If you want to overnight you really need the equivalent of 4 GC lead acid batteries.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
austinjenna
Columbus, Ohio
Posted: 10/24/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Doubtful, my storage lot is 2 miles away. It takes a few hours for a residential to cool down
riflegunbuilder
Georgia
Posted: 10/26/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
I just went from Ga. to San Antonio and back. No problems 2 group 27 Interstate deep cycle batteries.
austinjenna
Columbus, Ohio
Posted: 10/27/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
My question was more regarding the run time while not moving. I know the truck will charge the batteries while moving. Mine had to deal with it being in the storage lot and being able to start it the day before so what could I expect for the run time.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 10/27/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I did a test when we first got ours, ran the Fridge for 36 Hours on the two size 31 12V batteries and battery voltage was still at 12.6. Now nothing else was in use so fridge was only load. This is with a Whirlpool fridge, different brands might have a different power draw.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Cummins12V98
on the road
Posted: 10/27/21 09:31am Link  |  Quote  |  Print  |  Notify Moderator
What was the outside and inside temps surrounding the refrigerator?
Michelle.S
Posted: 10/27/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Fridge was set for 34 and freezer was zero, outside was spring in Western NY, so night time lows 40 to 50 daytime 60 to 70, best I can remember, after all it was 6 1/2 years ago.
