RV.Net Open Roads Forum: Fifth-Wheels: Furnace Not working....
 > Furnace Not working....
md_procouple
Parkville, Md.
Posted: 10/17/21 05:36am Link  |  Quote  |  Print  |  Notify Moderator
Hi every one... We have a 2008 Montana and just started Full-timers now and have a problem... went to turn on the furnace last evening and No heat... Just filled the propane and have hot water, The thermostat seems to be working because the A/C is working normally. The furnace worked great last winter, So were a bit perplexed. Any Help would be appreciated.
Vickie, Me, and "Scruffy" our dog make THREE
Fulltimer50
Eloy, AZ
Posted: 10/17/21 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Can you tell us what your furnace is doing?
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
memtb
Wyoming
Posted: 10/17/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Yes......the more detail you can provide, the more that we may be able to help! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
bgum
South Louisiana
Posted: 10/17/21 07:21am Link  |  Quote  |  Print  |  Notify Moderator
More info is necessary but we can start by blowing spider webs and others out of the burner.
TXiceman
Full Time RVer
Posted: 10/17/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Is the fan even trying to start and do the purge before igniting? If you get the fan to run, do you hear the ignitor? Have you checked the 12 volt fuse for the furnace?
Lots of questions before a good answer.
Ken
Amateur Radio Operator.
md_procouple
Parkville, Md.
Posted: 10/17/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Hi every one... Good News... after playing around with the electrical system... found a a red wire had became disconnected... tightened the crimp a little and every thing fired up as normal !! Thanks for the help
laknox
Arizona
Posted: 10/18/21 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget that sail switches are known to go bad, too!
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
