RV.Net Open Roads Forum: Class A Motorhomes: 2006 Newmar essex
 > 2006 Newmar essex
rabnud
california
Posted: 10/18/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
pressure washed batterys (as i have done many times) now factory alarm keeps activating and resets itself every time I run or drive it
also when I use the remote system to say set ac temp or switch to heat or try and turn on inverter etc
the display reads "Lack of module"
any ideas out there
* This post was edited 10/18/21 12:53pm by rabnud *
Bruce Brown
Northern NY
Posted: 10/18/21 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Would it be safe to assume you have automatic generator start?
If so my guess would be you somehow unplugged the battery sensor and/or it's full of moisture.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
rabnud
california
Posted: 10/21/21 09:35am Link  |  Quote  |  Print  |  Notify Moderator
yes has auto gen start ;;I dont relate that in any way to the alarm going off at random but will certainly take a look see the battery sensor as I understand is a heat sensor and simply shuts off the charging if batterys overheating ?
Bruce Brown
Northern NY
Posted: 10/21/21 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Moisture in anything electronic can cause weird things to happen.
 > 2006 Newmar essex
