RV.Net Open Roads Forum: Replacing New Trailer King RST+: Only Option Is Carlisle??
 > Replacing New Trailer King RST+ : Only Option Is Carlisle??
obie311
Aux Arcs
Posted: 10/26/21 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Rollochrome wrote:
Sailuns are apparently bad now from Vietnam, at least this batch.
Since I just put four Sailuns from Vietnam on my rig, can you give me a specific referral as to where you got this info?
Thanks.
fj12ryder
Platte City, MO
Posted: 10/26/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Several posters on the Grand Design forum have described tread separation with their Sailun tires purchased earlier this year and manufactured in Vietnam.
Howard and Peggy
"Don't Panic"
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 10/26/21 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
There have been a few on the Montana Forum, and I just encountered a loss of the inner third of tread on a 2 year old Sailun made in China, tire never lost air so we had no idea it happened until several days later. Needless to say, I'll be keeping a much closer watch on the other tires.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Rollochrome
Fort Worth, Texas
Posted: 10/28/21 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
HI OP HERE...
OK HERE'S THE SPECS ON THE TRAILER.. THANKS FOR EVERYONES HELP BY THE WAY. MY FIRST 5ER.
STICKER SAYS:
GVWR 15,500 LBS
GAWR EACH AXLE 7,000 LBS
1999 Saved By Grace Alone Thru Faith Alone! Thank You Jesus!
2019 F-350 LWB 6.7 4wd XLT-FX4-3.31 on Michelin Defender LTX M/S
2022 3850BH Cruiser South Fork on Carlisle CSL 16
TxGearhead
Posted: 10/29/21 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
I had a blowout on a Sailun on our 5th. I replaced with Herculles. So far great.
I have Carlisle on a dual axle boat trailer and 2 utility trailers no issues. Had the Carlisles on a Montana 5th wheel no issues.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Cummins12V98
on the road
Posted: 10/30/21 02:31am Link  |  Quote  |  Print  |  Notify Moderator
Was it China or Vietnam made?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JIMNLIN
Oklahoma
Posted: 10/30/21 05:39am Link  |  Quote  |  Print  |  Notify Moderator
Sailun like other tire mfg has many different tire types...S637 is just one of them.
Even the S637 has 16"/17.5"/19.5" sizes so its important in reporting which Sailun size/load range product had a blowout.
Several years back one one member posted he had a Michelin XPS Rib blowout. However later we learned the tire was 6 years old and had 30k+ miles on it. But more importantly he ran the tire till it shredded down to the rim. No blow out ...just a run flat.
Some folks got upset about finally a XPS Rib blowout and there no different than a ST tire.
Makes a big difference when all the facts come out.
GaryUT
Northern UT
Posted: 11/03/21 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
I would look at the Goodyear G614 it is a load range G tire.
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
TxGearhead
Posted: 11/03/21 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
It was a S637 215/75/17.5 LR H. The blowout happened in August 2020. I replaced the Sailuns in January 2021. The trailer is a 2018 Landmark built in 2017. I don't remember the tire build date or its country of origin. I do remember the tire build date was appropriate for the trailer build date.
bluefishgary
Middle River,MD
Posted: 11/04/21 05:05am Link  |  Quote  |  Print  |  Notify Moderator
I also have the sailun tires,they replaced,The goodyear endurance.
I have a 3 axle toy hauler 18,000 lbs
Mine were built in not China, they were built end of January 2021. They are 16"
And F rated @ at 110 lbs. I run only
90 psi as that's more than enough for my load.so far so good . Total miles so far
6,000 miles. They do ride harder than the goodyear but a much heavier tire.
2019 Ford DRW C/C
2017 Vintage with living quarters 44'3 Axle
I caught a fish once -it was fun
