RV.Net Open Roads Forum: Replacing New Trailer King RST+: Only Option Is Carlisle??
 > Replacing New Trailer King RST+ : Only Option Is Carlisle??
cummins2014
Utah
Posted: 11/04/21 08:44am Link  |  Quote  |  Print  |  Notify Moderator
You are saying you bought F rated Sailuns, I am pretty sure they are G rated @ 110 psi .
You said , I quote " Mine were built in not China ". Whats that mean were they built in China , or were they built elsewhere ??
* This post was edited 11/05/21 07:25am by an administrator/moderator *
Cummins12V98
on the road
Posted: 11/04/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
cummins2014, to be polite he could use a lesson in punctuation.
I don’t proclaim to be an expert on the subject but it simply makes no sense.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
buc1980
houston tx
Posted: 11/04/21 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
For sure Sailun made in Vietnam are trouble but then what tire for heavy trailers Goodyear 614 way to expensive.
* This post was edited 11/04/21 02:50pm by buc1980 *
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
TxGearhead
Posted: 11/05/21 08:33am Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
TxGearhead wrote:
I had a blowout on a Sailun on our 5th. I replaced with Herculles. So far great.
I have Carlisle on a dual axle boat trailer and 2 utility trailers no issues. Had the Carlisles on a Montana 5th wheel no issues.
Sailun like other tire mfg has many different tire types...S637 is just one of them.
Even the S637 has 16"/17.5"/19.5" sizes so its important in reporting which Sailun size/load range product had a blowout.
Several years back one one member posted he had a Michelin XPS Rib blowout. However later we learned the tire was 6 years old and had 30k+ miles on it. But more importantly he ran the tire till it shredded down to the rim. No blow out ...just a run flat.
Some folks got upset about finally a XPS Rib blowout and there no different than a ST tire.
Makes a big difference when all the facts come out.
Last night I remembered I kept the original Sailun spare since it had less than 30 miles on it. I checked the sidewall and it has a date code code of 4316 and made in China. That would make it less than 4 years old when it blew.
The unknown variable is that we are the second owners, so no telling how the tires were maintained. I watch pressures pretty close and use a TST tire monitor.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
TxGearhead
Posted: 11/05/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
I think it's a **** shoot. Goodyear, Sailun, Hercules, close your eyes and pick one.
We just got home from on the road...NASCAR at Kansas City and a few days in the Ozarks. We were parked/camped next to a big Newmar diesel that was towing a matching "stacker" type trailer. He had a mix of Goodyear and Sailun on the 3 trailer axles. He didn't like either of them, citing unusual wear patterns. Probably a good chance it was trailer axle issues.
* This post was edited 11/05/21 09:14am by TxGearhead *
cummins2014
Utah
Posted: 11/05/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
It made no sense to me either . [emoticon]
