RV.Net Open Roads Forum: Tech Issues: Question on changing leaf springs on 5'er
 > Question on changing leaf springs on 5'er
phemens
Montreal, Canada
Posted: 10/19/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I will be changing out the flat leaf springs on my 2012 5th wheel on all 4 wheels. Was wondering if there is any advantage to doing it by axle (i.e. both wheels on one axle, then both on other) vs. just doing one side at a time (both wheels on one side, then the other). 2nd way would reduce some of the setup time I guess.
Thanks in advance!
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
SDcampowneroperator
South Dakota
Posted: 10/19/21 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Both on one axle. You will need to lower and raise it to change out the spring, then align it to the centering bolt.
While you are at it its a good time to replace shackles, bolts amd bushings.
phemens
Montreal, Canada
Posted: 10/19/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Shackles were all done 2 seasons ago (changed to the lubed kind)
I was under the impression I could lower 1 side of the axle at a time instead of both sides?
Cummins12V98
on the road
Posted: 10/19/21 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Use a TrailerAid Plus and do one at a time.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
pianotuna
Regina, SK, Canada
Posted: 10/19/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure to have a wheel alignment done after the springs have been renewed. DAMHIK
Regards, Don
phemens
Montreal, Canada
Posted: 10/19/21 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Good catch Don, I will!
time2roll
Posted: 10/19/21 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I put my entire trailer up on jack stands and did one side at a time. Seemed easier since I was replacing the equalizers etc that connect to both axles. A day to lift, day for each side then down made for three weekends.
Mine was out of alignment due to sagging springs so once replaced all was good.
675w Solar pictures back up
Veebyes
Posted: 10/20/21 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Nice to be able to lift up the whole thing one time but if that is not practical one side at a time. Leave it on the truck if doing one side at a time.
As suggested, while up there might as well replace & upgrade shackles etc. as well. Builders put on minimum spec hardware. I upped my spring pack from 6 to 7 leaf. No worries about breakage now.
2007 Alpenlite 34RLR
phemens
Montreal, Canada
Posted: 10/20/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
No worries on the shackles, I replaced them with heavy duty Moryde ones with the wet bolts 2 seasons ago. I added an extra leaf to the springs when ordering and will replace all the hardware on the springs.
2oldman
NM
Posted: 10/21/21 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Is something broken, or preventative maintenance? My leafs are still good after 18 years - or at least they look and work fine! Youtube got anything?
* This post was edited 10/21/21 04:43pm by 2oldman *
