RV.Net Open Roads Forum: Fifth-Wheels: Alignment...I think!
 > Alignment...I think!
SH
Lynden, WA
Posted: 10/19/21 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
So...brand new tires, a 3000 mile trip and this happens. Tires have worn perfect for the past 15 years. PSI and temps were all good for the entire trip. Got home and washed the rig and saw this wear on the front axle right side. Any ideas as to what the problem is?
https://www.amazon.com/photos/shared/WfI83GAHQZ2Bgsc7VnncTA.nERMFiG0c0jPuBar2s_ZHY
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ">
schlep1967
Harrisburg, PA
Posted: 10/20/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Didn't look at the pic but if you don't recall hitting any curbs on the trip, the only change was the tire installation. First make sure the wheel is actually seated properly on the hub. If that looks good, check for damage from improper jacking by the mechanic that may have caused the problem.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
BarneyS
S.E. Lower Michigan
Posted: 10/20/21 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Here is your picture.
If you will follow these directions exactly, it is very easy to post pictures on our forums. One of our moderators, 1492, developed this photo posting app to post your pictures. It works for other internet sites also. There is no need to have a separate hosting site for your pictures in order to use it.
It is very simple to use.
1. Upload your picture from your computer to the app.
2. Copy the resulting URL.
3. Paste that URL into your post without ANY changes. No additions or deletions.
Your picture will then appear in your post and be properly sized for use on our forums.[emoticon]
I have posted a test thread here for members to try out the app and see how it works. That thread is ONLY for testing however and not for comments on pictures. Good luck.
Barney
Not towing now.
Lightning55
Pleasanton, CA
Posted: 10/20/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
If only one tire is wearing unevenly like that, I would bet it's probably a bent axle rather than a misalignment. It's wearing pretty bad so it should be pretty apparent what's going on.
laknox
Arizona
Posted: 10/20/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
If you do want to have the alignment checked, do it at a heavy truck shop and not an RV dealer. Surprisingly, it's not stupid expensive, in most cases. Also, if you're using the same 15 y.o. trailer, have you checked your spring hangers and shackles? They could be worn, causing the axle(s) to get sloppy.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
cummins2014
Utah
Posted: 10/20/21 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Could you tell us what brand of tire that is ,I have seen several G614's cup ,and wear like that over on the Montana forum . I ran G614's several years ago ,and they wore somewhat like that on the edges , but it was all four .
MFL
Midwest
Posted: 10/20/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Agree with Lyle, on place for alignment check, and could be elongated hanger, shackle, or worn out bushing.
Also someone mentioned possible bent axle, from improper jack placement during tire change.
Jerry
MT BOB
Montana
Posted: 10/20/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
From what I can tell from that pic, something rubbed against that tire, or a defective tire.
schlep1967
Harrisburg, PA
Posted: 10/20/21 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Once the pic was posted I thought the same thing. Did they install taller tires and is there anything above that tire it could be rubbing on?
MT BOB
Montana
Posted: 10/20/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Or caught something in the wheel well.Would not take long at highway speeds.
