RV.Net Open Roads Forum: Travel Trailers: over filling
 > over filling
bigorange
Tucson, AZ
Posted: 10/25/21 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
If the process Charles suggested doesn’t work, you can pretty easily take the pump apart and flush it out and manually unstick the check valve. On my trailer it’s harder to access the pump than it is to take it apart.
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
hohenwald48
Nashville, TN
Posted: 10/26/21 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Second Chance wrote:
mobeewan wrote:
Doesn't matter what type of fresh water tank fill system that you have for your trailer, water can still leak past the pump internal check valve, filling the tank.
Not quite true. With our system, when all the valves are set for city water the pump is out of the system.
Rob
And the check valve is what keeps the pump out of the system. If it fails, and they often do, the pump is back in the system.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
mobeewan
Hampton, Va
Posted: 10/26/21 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
X
Danford50
North Carolina
Posted: 10/27/21 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
I found my problem and it was on the water pump it has a cut-off value that was in the open position, i turn it off and everything appear to be normal
Vintage465
Prunedale CA.
Posted: 10/27/21 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I've never had city water get past my pump and back into the tank. If if did I'd do what CharlesinGA says.......if that didn't work, I'd put a Shark-Bite check valve on the downstream side of the pump and be done with it.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
 > over filling
