rutzbeck
Haines, AK
So yesterday I am in the process of unloading my camper and of course I'm at the highest it needs to go, when one rear jack stops working. It wasn't making any sound. I managed to complete the unloading process by stopping every so often and manually working the jack. After I got it down I checked the fuses in the camper. The Left rear jack's fuse looked alright but I switched to the Right rear and then put the Right rear's in the left rear. Both jacks worked. So why didn't it work earlier. Any idea's.
Kayteg1
California > Nevada
Dirty fuse connectors?
rutzbeck
Haines, AK
It doesn't look like it. The cover was in place and it looked pretty clean. I was wondering if it could be a sign that the fuse was about to go.
I replaced the board and remote a year and half ago. It is a happijak 4800. The jacks were replaced 3 years ago. The motor on that side is older.
jimh406
Western MT
I have a rear one that acts up from time to time. I don’t know why, but usually it’s during retracting.
mkirsch
Rochester, NY
If switching the fuses around made it work I would suspect dirty connections. Even if they don't "look" dirty.
Bedlam
PNW
Your fuse may also have a hairline crack that was pushed back together when reseating it. I had a batch of glass fuses that let go inside the end cap and would show good until you put a load on them - The same can happen in the plastic modular style.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
rutzbeck
Haines, AK
I'll clean it and change the fuse. Should I do anything other than can air to clean it?
ticki2
NH
Electronics cleaner and dielectric grease at you favorite auto store
'68 Avion C-11
'02 GMC DRW D/A flatbed
rutzbeck
Haines, AK
I'll try it. I know I have at least one of those.
Thank you
EricCO
Colorado
If it shows up again, try swapping the motors around to help isolate the problem.
You mentioned in one of the posts that the motor is older so it might be time to replace it.
2002 Ford F-350 CC LB PSD
2007 Travel Lite 960rx Ultra
2009 Lund 208 Pro-V GL with 250 hp Verado
