RV.Net Open Roads Forum: Fellow owner of 90's Sero Scotty D350 5.9L Cummins Diesel RV
 > Fellow owner of 90's Sero Scotty D350 5.9L Cummins Diesel RV
Posted: 10/22/21 01:20am Link  |  Quote  |  Print  |  Notify Moderator
If the 2 batteries under the hood are the only two, then you’re correct most likely one has been isolated for house use and one start battery.
However that is largely immaterial in figuring out the vehicle charging issue.
Sounds like diagnosis and repair is a bit out of your wheelhouse, so I’d try to find a private shop or maybe a private diesel pickup shop. Not that this is a diesel issue, but anyone who works on diesels has likely been around a 1st Gen Dodge Cummins more than a few times.
2017 Heartland Torque T29
