RV.Net Open Roads Forum: Travel Trailers: Another issue
 > Another issue
hohenwald48
Nashville, TN
Posted: 10/26/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
Before you turn on the water heater open the access door and lift the lever on the pressure relief valve and make sure water comes out and keeps coming out if the pump is on or you are hooked up. If no water your winter bypass valves are in the wrong position.
And if that's the case and you flipped those switches on there's a good chance you'll need a new water heater element. You can get them at Lowes or HD.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
 > Another issue
