RV.Net Open Roads Forum: Dinghy Towing: Tow Dolly Woe
Search only in Dinghy Towing
 > Tow Dolly Woe
Posted: 10/26/21 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
mkirsch wrote:
If the OP is dragged down a boat dock by his car, something is very very wrong.
But don't ignore human ingenuity. Just las week on youtbe I run into video of a boat, who I would estimate at least 15,000 lb, with about 12' width towed by F150.
The best point was going via 11' wide tool gates.
Why is it that someone always posts some extreme example and then basically says "well it "could" happen, somehow, somewhere, sometime..."
Is it like an innate need to refute EVERYTHING? (I call it the "arging that the sky isnt blue", rv.net syndrome)
2017 Heartland Torque T29
Posted: 10/26/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
ferndaleflyer wrote:
At that price get rid of it and buy a new dolly WITHOUT brakes. I have used this set up for 20+ years and have yet to have the first problem.
But you generally appear to be more mechanically inclined and savvy than most. And the OP could "need" them surge brakes, whereas you don't behind an air-braked pusher. (And you likely don't get wrapped around the spokes with much of the weight cop and towing fears that seem to proliferate this forum)
But it does raise the question that the OP mentioned. $600 to "service" the dolly (1 axle). What does that include? Did he get a quote to replace the actuator, new brakes and bearings? Or was that $600 plus parts and more labor to replace the actuator if needed? Big difference.
ferndaleflyer
everywhere
Posted: 10/26/21 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Grit you forgot to mention to take advice from those that have done it not those that heard or read about it. Mechanically inclined, maybe, but those Utube instructions sure make me feel like it sometimes. And I have the nerve to jump right in, LOL.
And the fact that the current toad on my dolly is a Smart car may help the no brakes deal. Carry on
JoeChiOhki
Sauvie Island, OR
Posted: 10/27/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Honestly, if you strike out finding a shop, look up the backing plate size and weight rating of the existing surge brakes and get an electric brake kit for it. Since its not a boat trailer, submergence is not an issue and you'll be able to live dial the braking impact the electrics trigger while testing it with a live load.
Electric conversion kits used to be fairly inexpensive since it was mostly just a swap of the hydraulic cylinder for the electromagnet piece designed to take its place and running of some new wire to your trailer plug if you are already wired up for electric trailer brakes on your vehicle.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
mkirsch
Rochester, NY
Posted: 10/28/21 06:36am Link  |  Quote  |  Print  |  Notify Moderator
OP doesn't "need" brakes. ferndaleflyer says so.
I'd ask why is it that someone always posts that nothing bad will ever-ever happen, and you don't need to worry about silly things like worst case scenarios?
My luck the second I become complacent a meteor will plop down in the middle of the road in front of me and I won't be able to stop because my tow dolly's surge brakes were shot and not working. But I didn't need them because nothing bad was ever-ever going to happen right?
ferndaleflyer
everywhere
Posted: 10/28/21 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Oh MY!!!!! I did have an airplane crash in my yard once but since I moved my original site location 20 years earlier it missed the house. Sh-t happens in real life.....you could avoid that meteor by just staying home, but wait, it might hit your house. Silly meteor!!!!
Hope OP finds someone to help him out. Its a real pain to need something done and find no one to do it.
Pete_k
Stantonville Tn
Posted: 11/05/21 05:44am Link  |  Quote  |  Print  |  Notify Moderator
mkirsch wrote:
The whole "It's illegal" discussion is irrelevant here, because this is for a car dolly, not a commercial trailer, and not in BC.
Used to get dragged down the ramp 3 or 4 times per day. But then again with a Yacht. Plus we always stopped when the boat hit the water. This was with a class 8 single axle semi also.
2022 Ram Big Horn DRW on order">
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
2012 Landmark Key Largo soon to turn into a Truck camper.
 > Tow Dolly Woe
