RV.Net Open Roads Forum: Class C Motorhomes: Protection from freezing
 > Protection from freezing
Anza-Borrego Desert SP area
Posted: 10/23/21 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
If your tank heaters are 12 volt they’ll consume a bunch of battery amps.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
pnichols
The Other California
Posted: 10/23/21 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
MDKMDK,
Any idea of the watts they draw?
A good question, Don.
I found a link to the UltraHeat wepage that shows what size heating pads they offer and the amounts of current the different size pads draw. Note that the pads cycle ON and OFF under control of their built-in thermostats, so the current that the various pad models draw should be "way less", or at least "a little less", than the steady-state current values shown in the specs.
For versatility to drycamp or hookup camp in cold temperatures, I'd recommended using either the 12V pads or combination 12V/120V pads on an RV's tanks. Of course when hookup camping with only 12V pads on one's tanks, the RV's built-in converter should still supply plenty of 12V current for the 12V-only pads, so I really don't see the need for the combination 12V/120V pads in an RV ... the 12V-only pads should always be OK.
Here's the link:
https://www.ultraheat.com/ultraheat-rv-tank-heaters
Phil, 2005 E450 Itasca Spirit 24V
MDKMDK
Lockdown Gulag
Posted: 10/23/21 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
MDKMDK,
Don, I have no idea. They're factory installs, but they had to be added by the Canadian dealer, after they received the unit from the factory. For reasons unknown, they could not be "factory installed" @ Winnebago. Cross border rules/regulations? Next time I'm under the vehicle, I'll see if I can see a label to identify them. My gray/black tanks are 36 gallons each, fwiw.
I did find a blog that discusses them in some detail, and mentions between 4A and 11A of current as a typical range. They link a couple of examples of after market add ons. Though they don't say, I'm assuming that's DC amps.
https://vancampinglife.com/when-should-i-turn-on-my-rv-tank-heaters/
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
bobndot
Posted: 10/24/21 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Amazon has a 12v , 12”x18” tank pad @ 4.8 amps.
Would that be about 100 watts of heat ? ?
MDKMDK
Lockdown Gulag
Posted: 10/24/21 09:02am Link  |  Quote  |  Print  |  Notify Moderator
P = I * V or W = A * V
So, about 60W.
As an after thought, Winnebago probably used the most cost effective (aka cheapest) heaters they could safely/legally install.
MT BOB
Montana
Posted: 10/24/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
"As an after thought, Winnebago probably used the most cost effective (aka cheapest) heaters they could safely/legally install."
Had to smile,as probably very true!
OK back to my coffee.
bobndot
Posted: 10/24/21 11:08am Link  |  Quote  |  Print  |  Notify Moderator
So, about 60W.
Tnx for formula [emoticon]
'Built to last the warranty' [emoticon] I'm surprised the heaters con't to operate.
Posted: 10/24/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Phedley wrote:
We just bought this unit so there’s going to be a learning curve. That’s what I thought but I wanted to get more input. We will be plugging in but sure if holding tank heater will work. Thank You
Looks like the regulars are off the track here discussing the finer points of tank heater wattage….no surprise.
Your question is very vague, other than you’re letting the audience try to figure out how cold it might be based on your description of travel route.
Understanding that you don’t know how cold you can operate your rig, still try to ask questions objectively.
And as no one yet has come by and said “I have that model and we ______ down to _____ degrees with no issue.” , I’d suggest figuring out how your camper operates prior to the trip and then have some contingency plans and extra materials.
No one can predict the weather 2 months ahead. Living on the I40 corridor for many years right in the middle of your route, I can tell you it could be 60 degrees or 0 degrees on Christmas. And while lows in the 20s at night and above freezing during the day likely won’t require much if any extra effort, 0 at night and 30 during the day most certainly will.
Easier thing to do is learn how to do a quick winterization. And if it be gettin too cold, just winterize up the fresh water side and keep a little pink or blue juice for the tank(s) and flushing.
2017 Heartland Torque T29
MDKMDK
Lockdown Gulag
Posted: 10/24/21 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
So, about 60W.
NP on the formula. It's US Formula One day today, so sort of appropriate?
I have only ever tested them once, and that was briefly in the driveway. They look like they would peel and fall off if used for longer than a few minutes.
I secured the wiring myself shortly after the dealer installed it in 2018. They didn't get the wiring and pads when the vehicle was delivered to them. Took about an extra week to get the parts. I had a look underneath when I got home after the work. They left the wiring dangling loosely underneath, so I added some inexpensive plastic wiring conduit and some cable ties to try to secure/protect them a little more. So far, so good.
bobndot
Posted: 10/24/21 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Crawl underneath the rv ? Now you’re pushin’ it. [emoticon]
I will check mine to see how they look or don’t look. Maybe they fell off [emoticon]
