RV.Net Open Roads Forum: Travel Trailers: Add Awning To Slide?
 > Add Awning To Slide?
JBarca
Radnor, Ohio, USA
Posted: 10/29/21 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Arn wrote:
Not enquiring about a slide topper, not enquiring about an awning going over the slide. Talking about attaching an awning to the slide.
This may be worth a try. Call Jayco directly and ask for customer service. Have the camper VIN number handy to give to them so they know exactly which camper you have.
Ask if they can provide a stud wall plan for the area you want to mount the awning to. Then you can see if there is extra support in the wall structure and where it is located.
I have seen this exact question asked to Jayco from a friend who bought a new Jayco and wanted to add a slide topper. He needed to know where and if there was structure to mount the roller arms to the slide wall.
And I called Jayco myself when helping a friend with his large Eagle Fifth wheel to look up the screw length in the gutter rail screws. In this case the technician looked up the wall plan and told me over the phone the size of the aluminum tubing that was used.
This was all pre Covid, not sure if on site staff is still available to look up things like this with so much remote cutometer service working from home now a days. But, it is worth a shot. They have given good customer service like this in the past. A sign of at least one RV company left who will help their customer with these kinds of questions after the sale.
Hope this helps,
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
Arn
Ottawa Valley, Ontario, Canada
Posted: 10/30/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Hope this helps,
John
Good info. Thanks!
Arn
1958 Me
1963 Her
2015 Jayco Jay Flight 33RLDS
2020 Silverado LTZ Crew, 5.3 Max Trailering Pkg.
bucky
Raleigh metro
Posted: 10/31/21 03:30am Link  |  Quote  |  Print  |  Notify Moderator
Something else to consider is that with the slice extended and an awning on it also extended a site may be to narrow to accommodate the extra width. Trees may come into play as well. I do like the idea though.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Clarkk
Posted: 11/28/21 09:42am Link  |  Quote  |  Print  |  Notify Moderator
The steps to installing an RV slide-out awning are to measure the depth and width of a fully extended sliding out room. Buy the right size sliding awning kit. What you need to do is choose the design that best suits your RV. Always check the product you ordered before starting to install the RV slide. Check the number of holes in the awning kit and count the amount of hardware included. You can add holes on the left or right side of the center lanyard, applying sealant before securing the screws. Add rubber sealant to the holes before securing them with screws. Install awning pipes. Take the end cap extensions and connect them to the brackets without fixing them with screws. Carefully slide the awning tube into the awning rail. Secure the awning tube by tightening the shoulder screws on the end cap extensions.
