RV.Net Open Roads Forum: Tow Vehicles: 2002 silverado 1500
Search only in Tow Vehicles
 > 2002 silverado 1500
Celica77
Pasco
Posted: 10/23/21 10:14am Link  |  Quote  |  Print  |  Notify Moderator
I know it has been asked about a thousand times but what can my truck tow? It is a 2002 1500 extended cab 4x4 5.3l. 3.73 gears. From what I am seeing is 8000lbs. My truck invoice says it has the tow package, which includes, transmission cooler, locking rear diff, heavy duty suspension, 8 wire trailer harness. So just curious if with that if the tow capacity stayed at 8000lbs.
Thanks
MFL
Midwest
Posted: 10/23/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Yes, you should be able to tow 8K. The misleading part...an RV trailer normally has a large frontal area, and huge sidewalls. If you are towing a flatbed trailer, with a load of bricks 8K would tow much easier.
You also need to be aware of hitch weight, as an 8K travel trailer may have 1K+ of hitch wt.
Looking to tow a TT with an older 1500 V8 3.73, I'd suggest staying at 7K or less actual ready to camp wt. If you have 4 passengers plus gear and lots in the bed of truck, that needs to be figured in too.
Jerry
Celica77
Pasco
Posted: 10/23/21 11:09am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 weekend warrior fk1900 Hitch Weight 650lbs Dry Weight 3887lbs.
Family of 4, will see 2-3 dirtbikes in the back of the trailer. Maybe a generator in the bed of the truck and the usual food and water in the tanks.
MFL
Midwest
Posted: 10/23/21 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
While that will likely be a load for your truck, sounds do able to me. Not sure of your travel area, but steep hills, or mountains will require lots of patience.
Welcome to the forum!
Jerry
valhalla360
No paticular place.
Posted: 10/23/21 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Truck payload is likely your issue. 8K trailer is likely 1000lb hitch weight plus whatever else is in the truck including passengers.
Look on the door jam. There is a sticker that shows the payload as it left the factory.
The other thing to consider is at 20yr old, is the engine and transmission in good shape?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Quartzsite, AZ
Posted: 10/23/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Pulling should be fine. Lifting the weight might not be. What’s the 2002’s payload max?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
JIMNLIN
Oklahoma
Posted: 10/23/21 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
The '02 5.3 is really down on power. I don't think you will like towing a 8k lb trailer.
We had a '06 1500 chevy 4wd 5.3 4 speed auto 3.73 gears and it really struggled with a 6660 lb wet weight trailer out here in the southern plains and 35-45 mph headwinds and in the NM/CO/UT mountains.
Its doable but just take it easy and forget about staying with the flow.
MFL
Midwest
Posted: 10/24/21 05:23am Link  |  Quote  |  Print  |  Notify Moderator
While the OP is asking, "can my truck tow 8K", his actual small TH is only 3,887 lbs dry. Even if he adds his 3 dirt bikes (750 lbs) plus stuff, he likely will not weigh over 6K, ready to go.
I agree the older 5.3s were down on power, but I think it will get the job done.
Jerry
LITEPHIL
AZ
Posted: 10/24/21 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I would stay under 7,000 lbs. I towed quite a bit with an 2002 5.3 3.73 at 7,000 and I would have to hit 1st gear at times. Was better then my 93 5.7 but the 5.7 never had to hit 1st gear. When it did hit 1st, it would accelerate right back up and hit 2nd gear for a short bit. I think 6,000 lbs would work ok.
2019 Chevy RST Silverado 1500
1954 Chevy 3100 Carryall 4x4
2002 Sandpiper T22
04 FXDL Harley
blt2ski
Kirkland, Wa
Posted: 10/24/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
8000 lb trailer capacity less family of four, 600-800 lbs depending upon of kids are preteen vs adult sized teens. Puts you at around 7000 lbs max trailer. Maybe a bit less. To stay under factory gvwr of around 12-13000 lbs.
You can sit, as noted, you might be slowish. You won't be the first trying to pull at max, slow more than you think you will or should. Don't let motor lug, find RPM that engine seems comfortable towing at on hills. My 2014 4.3 and 2000 5.7 have no issues in the 3000-4000 relm when really loaded on a steeper 3-6% freeway grade.
Have fun
Marty
2014 Chevy 1500 Dual cab 4x4
