RV.Net Open Roads Forum: Tow Vehicles: 2002 silverado 1500
Search only in Tow Vehicles
 > 2002 silverado 1500
Celica77
Pasco
Posted: 10/24/21 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the feedback! My initial question was more towards the tow capacity of the truck, since the invoice sticker said it came with the heavy duty suspension. Trying to find actual info is kinda hard. I know the 5.3 is the weaker link and it has 150k miles. 6000lbs was my goal for loading, don't do much dry camping so usually will have water hook ups and a dump station in the park. Im in Washington, and going to the coast is pretty flat until you hit the coast and same with going to the mountains is pretty flat until you get there. I already know I won't keep up with my father in law in his duramax pulling his 35ft fully loaded toy hauler!
Posted: 10/24/21 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
150k is not bad if the truck is in great mechanical shape.
I wouldn’t hesitate to pull your trailer.
I would not want to pull much more, comfortably, though with that truck. By comfortably, I mean power/trans/gearing. Chassis is ok for a larger longer trailer within reason, but 20 year old power and trans is not ideal to pull everywhere at the speed limits.
Let er rip with the trailer you have though!
2017 Heartland Torque T29
Brandon the Traveler
SC, NY, PA, WV
Posted: 10/24/21 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
When I read threads like this it makes me wonder how dad hauled 5 kids, mom, 3 packed coolers and a ton of other gear, out to Yellowstone then the Grand Canyon @ 1974. He was pulling a 25' Holiday Rambler TT with a 1963 Falcon 6 cylinder wagon. I think those things had about 75 HP lol.
I went.
Celica77
Pasco
Posted: 10/24/21 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah but what were the speeds back then? Back roads only 45mph no free ways.
SC, NY, PA, WV
Posted: 10/24/21 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
I forgot the Interstates did not arrive until 2010 LOL.
blt2ski
Kirkland, Wa
Posted: 10/24/21 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Interstates started getting built in Eisenhower time frame. So 50's!
But as noted, my 4.3 V6 has 50 more HP, down 35 lb ft of torque in motor, my 88&89 454's. 6 gears instead of three. I pull my equipment trailer with mini excavator better and faster with my 2014 2500. A bit better than my 2000 C2500 5.7 4 sp 4l80 trans.
My son towed his dodge conversion van from Wenatchee over Stevens pas, which is way harder pull than I90 with his 05, 4.8 V8, 3.42 gears, 4" lift and 33.5" tires. He survived. A bit slow.
Enjoy.
Marty
2014 Chevy 1500 Dual cab 4x4
MFL
Midwest
Posted: 10/24/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
This is amazing, just a bit over the top! If you could post a pic of this rig, hooked up, ready to hit the road, I will say "welcome back to the forum". [emoticon]
Jerry
blt2ski
Kirkland, Wa
Posted: 10/24/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Not as low on power, but in 92 did this with an 88 GM BB ext cab, 26' Terry Prowler. Found myself doing 15-20 mph in 1st gear. Not fun.
9 years later Thursday/Friday after 9-11, same trailer, 6.5td crew cab, did speed limit everywhere. Kids were 9-16. 1300 lbs of us. Same trailer 2000-2500 lbs heavier gcw. 4000 lbs over GM's gcwr! I'd do that trip in heartbeat again with same truck. My favorite truck I've owned. This 2014 1500 might be close behind, or get ahead of that one ...
Marty
hohenwald48
Nashville, TN
Posted: 10/26/21 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Probably by working on it twice a day and once at night. While you and your siblings were out playing around in the campground or sound asleep. [emoticon]
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
Sjm9911
New Jersey
Posted: 10/26/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Just take your time, it will be a dog on hills and you will not be setting any land speed records. But you'll be fine.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
