RV.Net Open Roads Forum: Class C Motorhomes: Stability control
 > Stability control
Phedley
Posted: 10/23/21 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have a just acquired 2007 winnebago Navion that has stability control issues. I’ve checked tire pressure air bag pressure all is good. Any suggestions on how to correcting this horrible feeling of being out of control?
MT BOB
Montana
Posted: 10/23/21 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
https://alwaysonliberty.com/2020/03/winnebago-view-suspension-upgrades.html/
https://www.lichtsinn.com/rv-parts/sumo-springs-view
Phedley
Posted: 10/23/21 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
2007 Avion 23H
2017 Nissan Rouge
Harvard
51.6N 114.7W
Posted: 10/23/21 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Your unit has too little caster.
MDKMDK
Lockdown Gulag
Posted: 10/24/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Slow down a little? These things are essentially boxes mounted on a light chassis that usually loads them to within 1000 pounds or so of the GVWR. As a result, they are susceptible to road conditions, and cross winds, and 18 wheeler bow wash. There are some suspension mods you can try, as has been suggested, but honestly, don't expect it to handle like a sports car, because it isn't a sports car. Drive it, you'll get used to the handling limitations, it just takes practise. Mine felt odd when first driven, but after some driving I got the hang of it.
As an after thought, get the alignment checked at a Benz Sprinter capable dealer. There may be siginficant wear on the suspension on an older T1N based motorhome. Forgot yours is 2007 vintage.
* This post was edited 10/24/21 09:25am by MDKMDK *
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
klutchdust
Orange, California
Posted: 10/25/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Front and rear stabilizers, wheel alignment and Koni shocks for my Cambria.
mgirardo
Brunswick, GA
Posted: 10/26/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I would start with an alignment. Replacing or adding parts before having the alignment checked could be a waste of money. If it needs new ball joints, they find that out during the alignment.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
klutchdust
Orange, California
Posted: 10/26/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
-Michael
Doubtful that anyone that has upgraded their suspension from stock has any regrets. Just changing the shocks on my Cambria eliminated the side to side roll and that awful RR crossing banging that is all too frequent. Alignment, done right, will help for sure.
MDKMDK
Lockdown Gulag
Posted: 10/26/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
-Michael
Agreed on not throwing money at it, and adding all the usual suspects that others suggest, before getting the alignment check. It's easy to spend a fortune on these vehicles, and get negligible results, and ride is a very subjective topic, after all.
Gjac
Milford, CT
Posted: 10/27/21 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
MDKMDK wrote:
-Michael
Good advice. The other thing I would do before the alignment is to check your weight distribution of the MH each tire should carry at or near as possible the same weight. If not try to redistribute the stuff you carry. If it is on a Mercedes chassis they usually ride better than the Ford stock. What chassis do you have? How many miles on the MH? Do you see any unusual tire wear? Do you feel vibration in the steering wheel or seat? Has it ever been aligned by the PO? If you can answer some questions we can help you narrow down you handling issues.
 > Stability control
