RV.Net Open Roads Forum: Class C Motorhomes: Stability control
 > Stability control
Phedley
Posted: 11/02/21 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone doubled the rear shocks and stabilizer? Another words the rear suspension would have 4 shocks and 2 sway bars. What’s your thoughts.
MDKMDK
Lockdown Gulag
Posted: 11/02/21 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
No, on doubling the shocks or other hardware.
I am in the process of adding Sumo Springs to try to mitigate the curb roll, and sway from driveways and 18 wheeler bow wash. If the handling improves, that would be a bonus, but I'm only after a low speed rock and roll improvement. These things have very mushy suspension, and the gap beteeen the frame and suspension bump stops is pretty wide, probably to soften the ride, but the trade off is serious wobble entering/exiting even slightly angled grades and driveways. If it works, great. If not, no harm done.
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Phedley
Posted: 11/02/21 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yea bought some of the SumoSprings also. The yellow one. Have not installed yet. Let me know how your results are. I’ve driver 18 wheelers and such but never this bad.
klutchdust
Orange, California
Posted: 11/03/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
The curb roll on my 30' Cambria was minimized by the addition/changing of the shocks to Koni vs. what Ford installed on the chassis. Curious to see what the Sumo can do. Was under the impression they were meant to be more of a weight bearing device.
MDKMDK
Lockdown Gulag
Posted: 11/03/21 08:49am Link  |  Quote  |  Print  |  Notify Moderator
They're a constant contact compressible bump stop between the suspension and frame, is how I would describe them.
At least the ones I'm trying are. I have added the yellow rears (1400lbs combined support at 50% compression) SSR-338-54, and so far, they have done what they promised. I'm seeing reduced push/sway due to cross winds/big truck bow wash, and I used to bottom out the tail, if I left/entered my driveway a little too fast. That hasn't happened either.
I was impressed enough that I ordered the fronts SSF-106-47 (1000lbs at 50% compression) hoping to add some more stability to cornering and curb roll. Even a bit of improvement will be worth it. Still waiting for them to arrive.
My factory shocks are Bilsteins, and I haven't read anywhere that changing them out was worth the effort/cost, so I'm waiting to see if the Sumos alone will give me enough improvement.
Phedley
Posted: 11/12/21 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
I just installed the yellow sumo springs what a difference. I will be putting them on the front. Thanks for the update!
bobndot
Posted: 11/13/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know if TL Stableloads help on these rvs ? Might be another option for some experiencing side to side motion. They worked well with my pickup hauling TC’s.
This link explains and reviews what they are.
https://www.torklift.com/blog/entry/cust........leloads-suspension-stabilizer?format=amp
MDKMDK
Lockdown Gulag
Posted: 11/13/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Good news? I've decided to wait for a while, and a few more miles to add the fronts to my chassis. The rears do seem to help, so I may not need the fronts after all, but I have them, if needed. Weather is starting to chill up here, which also helped decide which way to proceed.
Snomas
Sedona, AZ
Posted: 12/29/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
I installed front and rear sway bars, Bilstein shocks, safeT steering arm, wheel aligjment corrected tire pressure and it made a great improvement to my driving experience
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
rjstractor
Maple Valley, WA
Posted: 12/29/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Not very helpful, as the OPs motorhome is on a Mercedes chassis.
To the OP, I haven't seen too many handling complaints about the Mercedes chassis. Part of may be your expectations, depending on what they are. Although some say they do, these things don't drive like SUVs. Have you owned other motorhomes?
I haven't seen anyone mention weights. GVWR is pretty low for a motorhome this size, and it would not take a huge overload on the rear axle to make it handle terribly. I would start by knowing your weights.
 > Stability control
