RV.Net Open Roads Forum: Tech Issues: Windshield gasket leak
 > Windshield gasket leak
Teleman
Clayton, CA, USA
Posted: 10/24/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
The rubber gasket at the top of the windshield over the dash on the driver's side has a slow leak. How do I address this?
opnspaces
San Diego Ca
Posted: 10/24/21 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
It will depend on many things. But first we really need to know what kind of RV you're dealing with.
Is it a class A Class C a Class B van or a cabover camper.? can you give us the year make and model so we can make a more educated guess?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
theoldwizard1
SE MI
Posted: 10/25/21 06:07am Link  |  Quote  |  Print  |  Notify Moderator
There is only one way to PROPERLY repair this. Have a professional remove the windshield and replace the gasket.
2 problems. I had to buy a new windshield to get a new gasket. If there is any rust on the surface under the gasket (likely) it must be properly repaired, primed and painted or the leak will be back shortly.
Dave H M
IL
Posted: 10/26/21 04:08am Link  |  Quote  |  Print  |  Notify Moderator
The wizard has the answer.
However you could run a strip of that touted eternabond across the top. [emoticon]
fyrflie
Martinez, CA. USA
Posted: 10/26/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
If your windshield is glued in place like a lot are, the gasket is just a trim piece.
You can take some windshield sealant, available at most auto part stores, pull the rubber back and squeeze the sealant into the suspected leak area.
During my recent windshield replacement, It was amazing at how many voids ( lack of sealant) there were on all sides of the windshield. Overall poor quality workmanship from Fleetwood.
Teleman
Clayton, CA, USA
Posted: 10/26/21 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
It's a 2000 Airstream Land Yacht 30' Class A.
Retired JSO
North Georgia Mountains
Posted: 10/26/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
We had a 2000 Newmar Mountain Aire. Going into a campground where the road went from flat to tilting a few degrees. The next morning I found daylight between the windshield gasket and the fiberglass. Took it to a glass company and they realigned it. About 3 months later, it happened again. I let the next owners figure it out.
Dutch_12078
Winters south, summers north
Posted: 10/26/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
First make sure it really is the windshield leaking. I've fixed more than one "windshield leak" by resealing the marker lights above it.
Dutch
2001 GBM Landau 34' Class A
