RV.Net Open Roads Forum: Fifth-Wheels: Help!
 > Help!
Locke123
Bunnell Florida
Posted: 10/24/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2021 cobalt saber fifth wheel. I had the toilet pipe block up and I’ve had it snake three times and it keeps filling back up within two days does anybody know what this could be or why it’s happening please help
enblethen
Moses Lake, WA
Posted: 10/24/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
Not using enough water!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MFL
Midwest
Posted: 10/24/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Along with lack of water in bowl, pipe from toilet may be too close to bottom of tank.
Jerry
enblethen
Moses Lake, WA
Posted: 10/24/21 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Solids can make a pyramid right below the toilet. You time using a hose and nozzle through the rig can knock it down. Use a piece of pipe with a tether cord to hold valve open. Tether is so it doesn't fall into the tank.
Back flushing from discharge outlet works in some cases.
Back flush device
Locke123
Bunnell Florida
Posted: 10/24/21 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
It’s in the pipe between the bowl and black tank
Locke123
Bunnell Florida
Posted: 10/24/21 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Can I use some sulfuric acid pipe removal on my toilet
enblethen
Moses Lake, WA
Posted: 10/24/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I would use a garden hose, stuck down through toilet.
Crappy job!
Locke123
Bunnell Florida
Posted: 10/24/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Already tried hose
time2roll
Posted: 10/24/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Need a camera down the pipe to find what is stuck and what it is getting hung up on.
I assume this is the first real use?
675w Solar pictures back up
eHoefler
ozark mountains
Posted: 10/25/21 04:57am Link  |  Quote  |  Print  |  Notify Moderator
Do you sit with the tank valve open?
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
 > Help!
