RV.Net Open Roads Forum: Technology Corner: Laptop battery stored in a cold car...?
 > Laptop battery stored in a cold car...?
d3500ram
Colorado
Posted: 10/24/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
I need to make an upcoming trip where I will be parking my car at the Denver airport for about 5 day.
I will have my laptop with me but won't be taking it on the plane. I would like to leave it stored in the car for that time. Denver could get into the 20's this time of year at night... don't anticipating it getting too much colder. Days are nice= 50's.
Should the battery be OK?
When I return, I will NOT be plugin in and using the computer right away... it will be a couple of hours that the temperature can acclimate back to normal before use.
I really do not have the option of not facing this situation. I am in Denver for work and then hopping a plane and do not need nor want to take it with.
jorbill2or
Full time
Posted: 10/24/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Turn it off . Going below freezing doesn’t hurt it . How do they ship these things In the winter. ( hint , In unheated trailers ) charging or “maybe” using might kill it, not storing it.
Bill
d3500ram
Colorado
Posted: 10/24/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, Bill.
Do you think it would be prudent to perhaps remove it from the laptop...
or per your comment, it should still be OK it it remains in place?
MT BOB
Montana
Posted: 10/24/21 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yes,remove from laptop. Learned that the hard way. Perhaps not all will have a parasitic drain, but most I have been around do.
opnspaces
San Diego Ca
Posted: 10/24/21 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
Hide the laptop before you get to the airport. No need to have someone observe you parking and then hiding something then leaving.
Probably doesn't matter if you take the battery out. But if it removes easily then why not?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
d3500ram
Colorado
Posted: 10/24/21 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
Hide the laptop before you get to the airport. No need to have someone observe you parking and then hiding something then leaving....
Good Comment! Will do.
Will also take battery out of the compartment as well before hiding.
pianotuna
Regina, SK, Canada
Posted: 10/24/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the battery. Wrap it in a blanket
When you return, leave the laptop in the blanket and warm slowly for 5 hours.
Then fully charge the unit.
Regards, Don
Ed_Gee
Central Oregon coast
Posted: 10/24/21 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
In my opinion, if a completely turned off laptop cannot go for 5 days without significant battery depletion, there's something wrong with it.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
valhalla360
No paticular place.
Posted: 10/25/21 01:10am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure if they are doing it lately but lots of destinations require you to turn on electronics...so a battery may be an issue going thru security as there is nothing to turn on.
Going down to 20F is a non-issue and it won't self drain over 5 days if you "shut down" the computer as opposed to just closing the lid which may just put it to "sleep".
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Bobbo
Wherever I park
Posted: 10/25/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
He is leaving the laptop in the car. It won't be going through security.
Bobbo and Lin
