RV.Net Open Roads Forum: Tow Vehicles: 2020 chevy trail boss
Search only in Tow Vehicles
 > 2020 chevy trail boss
Quartzsite, AZ
Posted: 10/25/21 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
I'm very happy with my 2020 Z71 but only pulling 5,200 pounds. Yes, I'd try up to 7,500.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Brandon the Traveler
SC, NY, PA, WV
Posted: 10/25/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
enblethen wrote:
Grand son has a 5.3 in GMC Sierra. Seems to be under powered!
Another pretty broad, vague, statement...
Seems to require oil when you change it, uses air for combustion, and gets hot when you run it.
I went.
enblethen
Moses Lake, WA
Posted: 10/25/21 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
It pulls hard going over the passes. It searches for gears when on slight inclines. This is empty truck with two people on board.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
JIMNLIN
Oklahoma
Posted: 10/25/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Older 5.3 were under powered compared to the '14 and up 5.3 with 355 hp and 383 torque with 6/8/10 speed trannies.
Wifes older '06 1500 5.3 with the 4 speed tranny chevy crew cab short bed Z71 3.73 gears would downshift on hills or fighting 35-40 mph head winds not towing.
She has the same truck in a 2016 model and its hands down a better towing platform. The new 5.3 has a lot more low end grunt and 5k-6k rpm hard pulling performance than the '06 for towing duties. And being a small block its not going to pull long steep grades in OD when towing in OD gears.
The OP didn't say but if the truck has the NHT tow packages its another big plus for towing duties.
Sounds like another good match.
blt2ski
Kirkland, Wa
Posted: 10/25/21 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
What year and transmission?
My 2014 4.3 has more grunt than my son's 05 4.8V8. outpulls my old 2000 c2500 with a 350V8..better than some of my old BB rigs too. A lot has to do with the 6 gears in transmission vs 3 and 4 spd transmissions. BUT my 4.3 has more HP than all of them. Better torque multiplication due to trans gears.
Older than 2014 are weaker motors!
Marty
2014 Chevy 1500 Dual cab 4x4
SC, NY, PA, WV
Posted: 10/26/21 03:36am Link  |  Quote  |  Print  |  Notify Moderator
Active Fuel Management?
enblethen
Moses Lake, WA
Posted: 10/26/21 06:26am Link  |  Quote  |  Print  |  Notify Moderator
2007 with 4l80 transmission
Posted: 10/26/21 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Not even in the same ballpark as the OP's truck.
2017 Heartland Torque T29
blt2ski
Kirkland, Wa
Posted: 10/26/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I'd bet my 4.3 would better do speed wise, get better mpg too!
Can't compare the 07 to a 2022. That's like comparing my old 89 4bbl 454 to the later vortex versions! Or an 8.1 with an Allison!
Marty
MFL
Midwest
Posted: 10/26/21 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Hey Marty, glad your truck is working out great for you! You are a good example of getting the job done, doing real work, with a 1500, and a 4.3! Better tires, or even air the OEMs to the max, maybe a bit of suspension tweaking, and they'll get er did.
Ford took a big jump with the 150s, using the Ecos, and 5.0 since 11-12.
Jerry
