RV.Net Open Roads Forum: Beginning RVing: Mildew pre treatment
 > Mildew pre treatment
rickhise
home
Posted: 10/25/21 04:26am Link  |  Quote  |  Print  |  Notify Moderator
Any recommendations for wiping everything in the camper down with that could minimize mildew.
I will leave 2 fans running this winter.
Roof vent open
Small window open
It’s stored under roof with side walls.
Also a full camper cover.
Wondering if the cover defeats my windows open an fans running.
I realize some will need more info, I’ll answer all questions
(Location, year, length, manufacture etc)
Manufacturers didn’t provide any info in owner’s manual
Campinghoss@51
Windsor NC
Posted: 10/25/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Put a few damp rid containers inside in different areas. Damp rid is your friend.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
prichardson
Lafayette, La
Posted: 10/25/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
A cover will defeat the advantages of having the roof vent and a window open for cross ventilation.
Timmo!
Far away from this WOKE website!!!!!!!!!!!!!!!!!!!
Posted: 10/25/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Small dehumidifier will offer you excellent protection. And we live in the PNW where mildew thrives like a king.
Posted: 10/25/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Not unless the cover is made from plastic or rubber and sealed up tight.
Air circulation is key.
And if there are specific areas that are known to mildew, I'd suggest direct air movement as close as possible to those areas.
2017 Heartland Torque T29
ktmrfs
Portland, Oregon
Posted: 10/25/21 10:17am Link  |  Quote  |  Print  |  Notify Moderator
yup, and it sounds like the OP has power to the trailer so my suggestion is to go to big box store and buy the smallest real (compressor driven) dehumidifier, turn it on low and maybe on a timer, and use the optional drain tube to drain water outside.
And IMHO one of the worst things you can do is cover the trailer with the blue (or silver etc.) plastic tarps. They don't breath and capture moisture.
The best thing to do is cover the trailer with a RV cover, they are breathable so moisture can escape through them.
* This post was edited 10/25/21 12:13pm by ktmrfs *
2011 Keystone Outback 295RE
way2roll
Wilmington NC
Posted: 10/25/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
I always find these mildew and moisture posts intriguing. in the RV's I have owned in the past decade (2 MH's and now a FW) and now living in a moisture prone environment near the shore, I have never had an issue with high moisture levels in the coach. I keep it sealed up when not in use - no vents open and it stays dry as a bone. Not sure what I am doing right but I've just never had an issue.
Timmo!
Posted: 10/25/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
We use this in our upstairs bathroom....good for 2200 cuft (about the size of a 40' trailer).
https://www.ivationproducts.com/products........m30-midium-thermo-electric-dehumidifier#
slider45
GA
Posted: 12/01/21 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe we should try a dehumidifier next.
schlep1967
Harrisburg, PA
Posted: 12/02/21 06:12am Link  |  Quote  |  Print  |  Notify Moderator
You are storing it in a dry condition. You should be able to close everything up and run a dehumidifier inside for a week, shut down the dehumidifier (cut power to the trailer)and keep it closed up.
That week should get the moisture level down and there should be no way for moisture to get back inside.
Note: Do not "heat the trailer". If you are making the inside of the trailer warmer than the outside you will get condensation.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
