Terry 25
Hagerstown, MD
for incapacitated brother. Where is drain for fresh water tank? Found low point drains toward front driver's side. Thanks
2016 F-250 Gas
2015 Rockwood 2608WS
pitch
NY
Drivers side underneath just below the fill port.
mdcamping
CT
Terry 25 wrote: for incapacitated brother. Where is drain for fresh water tank? Found low point drains toward front driver's side. Thanks
Hello I have an similar Jayco X20E The fresh water drain should be almost directly below the fresh water tank. Should be a small white plastic valve. Sometimes it's hard to see if there is water in the tank so If your not sure put a small amount of water in fresh water tank and turn knob till water comes out. Not really a flow directional on those cheap valves, so sometimes it good to make comparisons
good luck
Mike
edited 10/26/21 11:06am by mdcamping *
2022 F-150 3.5 EcoBoost 4X4 Supercrew GCWR 19,500 157WB
Payload 2476 Maxtow 13,800 3.73 Equalizer 4 Pt Sway Hitch
2017 Jayco Jay Flight 24RBS
Old TV, 07 Toyota Tacoma, Double Cab, Factory Tow Pkg, retired towing at 229K. (Son now owns truck)
Terry 25
Hagerstown, MD
Thanks for the helpful comments. Should have thought to look around the tank. No danger of freezing here in the foreseeable future. I'll check back with my findings soon. Camper is 90m away.
Terry 25
Hagerstown, MD
Thank you both, It was right where you said it would be. Cannot believe I didn't see it. BTW it was empty.
