RV.Net Open Roads Forum: Long Bed vs Bigger Overhang - off - roading
 > Long Bed vs Bigger Overhang - off - roading
Cortttt
Western US
Posted: 10/25/21 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have no experience at all with truck campers - am about to get one. I go "off-road" a lot by which I mean Forest Service/BLM roads. I've been looking at Northern Lite 8'11" and 9'6" models. The 8'11" requires a short bed and has a big overhang on the back while the 9'6" requires a long bed.
Trying to figure out which would be better "off-road"? An overhang that might scrape or a longer wheelbase with a shorter breakover angle and a larger turning radius?
I also wonder if having a long bed would have any effect on tippiness off road?
* This post was edited 10/25/21 02:52pm by Cortttt *
jimh425
Western MT
Posted: 10/25/21 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I think the overhang will be close to the same. The long bed should have an advantage on the road except the TC will be heavier since it is longer. You could also look at Bigfoot which is similar and who makes a short long bed model to reduce overhang in the 1500 series.
Cortttt
Western US
Posted: 10/25/21 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks! Northern-lite advertises the 9-6 as the shortest overhang and it is but I think you're right - looking at the pictures there really isn't that much of a difference.....Thanks for the Bigfoot recommendation. I will check it out.
KD4UPL
Swoope, VA
Posted: 10/25/21 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
I would get the long bed truck for sure. It will give you a much greater choice in campers. It will also ride better and quite possibly have a larger fuel tank. If I had anything dragging on the back of my rig I would want it to be the truck frame, hitch, or bumper; not the camper. If you drag a camper rear off road it will likely do significant damage.
Posted: 10/25/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
The difference in overhang between the 2 on short vs long bed is exactly the difference between the difference in the camper and truck bed dimensions. Or somewhere between 8"-13" depending on what brand of shortbed truck.
IMO, the rear overhang will generally not become an issue for length or breakover angle, before the terrain is arguably too rough for a pickup with 2 tons of high center of gravity load in the bed.
Unless you have some specific spatial limitations, and you have a blank slate for truck and camper, I'd say the longer the better. Every inch of space in a TC helps out IMO.
2017 Heartland Torque T29
Cortttt
Western US
Posted: 10/25/21 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks KD... Certainly more options with the long bed...
SoonDockin
Oklahoma
Posted: 10/25/21 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
While your thinking long bed, consider dual rear wheels. Ups your payload quite a bit and adds some extra stabilization with the wider track.
2019 Ford F450 KR
2018 Arctic Fox 1140 Dry Bath
Posted: 10/25/21 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Good point. I'm not the weight cops by any stretch and we were rockin' (literally and figuratively) a 4000-4500lb Arctic Fox on a short bed 3/4 ton for years. And I'd do it again. However if you're looking for a dedicated or mostly dedicated TC hauler for larger/heavier campers, the training wheels are a nice addition.
Again, you're not going to want to do any gnarly 4 wheelin that couldn't be accomplished by a dually, if you're hauling a 12' tall, 8' + wide, 2 ton box in your truck bed. (Although the srw would be more handy with camper unloaded and truck off wheelin with no camper in the back.)
Near DVNP, California
Posted: 10/25/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Buy or select the TC first then match a truck to it.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Cortttt
Western US
Posted: 10/25/21 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I was just looking at the dually thread on this forum [emoticon]. Hadn't thought of duallies before. Checking that option out now.
